MultiBody- part - Featurename - any name - colour change
With a parts created by sheet metal multibody work flow I want to return to the part & change colour depending on thickness.
I can run a basic rule on nornal parts but the children of multibody part have their names burried within a feature & this freature name change for the different solids (solid1, solid2, solid3 etc)
I'd like to find a way for an external rule to colour change any featurename.
Owner2229
HiI Andrew, maybe you can use something like this?
Dim oDoc As Document = ThisDoc.Document
Dim oFeat As PartFeature
For Each oFeat In oDoc.ComponentDefinition.Features
    Feature.Color(oFeat.Name) = "Cadet Blue"
Next
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
