Import sketched blocks from template
GeorgK
Advisor Advisor
GeorgK
Hello together,
how could I import sketched blocks from a template file?
Georg
xiaodong_liang
Autodesk Support
Autodesk Support
Hi Georg,
I am not sure what kind of template file you meant by, but with API, you can firstly define a SketchBlockDefinition, and insert it as a SketchBlock. There is a sample code in API documentation (<Inventor>\Local Help\admapi_20_0.chm)
Create and insert a sketch block definition into a part sketch API Sample. I posted here for your convenience:
Public Sub CreateSketchBlockDefinition()
    ' Set a reference to the part document.
    ' This assumes a part document is active.
    Dim oPartDoc As PartDocument
    Set oPartDoc = ThisApplication.ActiveDocument
    ' Create the new sketch block definition.
    Dim oSketchBlockDef As SketchBlockDefinition
    Set oSketchBlockDef = oPartDoc.ComponentDefinition.SketchBlockDefinitions.Add("My Block Def")
    ' Set a reference to the transient geometry object.
    Dim oTransGeom As TransientGeometry
    Set oTransGeom = ThisApplication.TransientGeometry
    ' Draw a 4cm x 3cm rectangle with the corner at (0,0)
    Dim oRectangleLines As SketchEntitiesEnumerator
    Set oRectangleLines = oSketchBlockDef.SketchLines.AddAsTwoPointRectangle( _
                                oTransGeom.CreatePoint2d(0, 0), _
                                oTransGeom.CreatePoint2d(4, 3))
End Sub
Public Sub InsertSketchBlockDefinition()
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oPartDoc.ComponentDefinition
    ' Create a new sketch on the X-Y work plane.
    Dim oSketch As PlanarSketch
    Set oSketch = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
    ' Set a reference to the definition named "My Block Def"
    Set oSketchBlockDef = oCompDef.SketchBlockDefinitions.Item("My Block Def")
    Dim oPosition As Point2d
    Set oPosition = ThisApplication.TransientGeometry.CreatePoint2d(10, 10)
    ' Insert the sketch block definition
    Call oSketch.SketchBlocks.AddByDefinition(oSketchBlockDef, oPosition)
End Sub
Curtis_Waguespack
Hi GeorgK,
Here is the iLogic rule that I use to do this.
I hope this helps.
Curtis
'check file type
If ThisDoc.Document.DocumentType <> kDrawingDocumentObject Then
Return
'identitfy the source template file
Dim SourceFile As String = "\\server\departments\CAD\Inventor\Templates\Standard.idw"
'define the drawing document
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveEditDocument
'get the current browser pane name
Dim oCurrentPane As String
oCurrentPane = ThisApplication.ActiveDocument.BrowserPanes.ActivePane.Name
'make sure the current browser pane is not the Vault pane to avoid error
If oCurrentPane = "Vault" Then
ThisApplication.ActiveDocument.BrowserPanes.Item("Model").Activate
'get the current sheet
Dim oCurrentNumber  As Sheet
oCurrentNumber = oDrawDoc.ActiveSheet
'delete symbols not in use
For Each oSymbol In oDrawDoc.SketchedSymbolDefinitions
	If oSymbol.IsReferenced = False Then
	oSymbol.Delete()
Next
'create list of symbols in use
Dim oExistingSymbolsList As New ArrayList
For Each oExistingSymbol In oDrawDoc.SketchedSymbolDefinitions
	oExistingSymbolsList.add(oExistingSymbol.Name)
Next
'Open the template
Dim strSourceIDW As DrawingDocument
strSourceIDW = ThisApplication.Documents.Open(SourceFile, False)
'iterate through the symbols
For Each oSymbol In strSourceIDW.SketchedSymbolDefinitions
	'look to see if the symbol is in the "in use" list
	If oExistingSymbolsList.Contains(oSymbol.Name) Then
		'do nothing
	Else
		' Get the new definitions.
		Dim oNewSymbol As SketchedSymbolDefinition
		oNewSymbol = strSourceIDW.SketchedSymbolDefinitions.Item(oSymbol.Name)
		'place the definitions in the drawing resources folder
		Dim oNewSymbolDef As SketchedSymbolDefinition
		oNewSymbolDef = oNewSymbol.CopyTo(oDrawDoc)
Next
'activate the original current sheet
oCurrentNumber.activate
'close the template/source file
strSourceIDW.Close()
GeorgK
Hello Curtis,
thank you very much. That's what I am looking for.
Georg
