multi sheet browser name in i logic
darrenwilliams
darrenwilliams
 hi
I am trying to put multi sheets assembly together and using the sheet title in the browser to make it easy to see what parts are being used so we can open up just that drawing
I have found a code on this forum for naming the drawing sheet after the part drawn but when you add a second sheet with a different part it still calls it the after the first sheet part
If (ThisDrawing.ModelDocument Is Nothing) Then Return
    modelName = IO.Path.GetFileName(ThisDrawing.ModelDocument.FullFileName)
    ActiveSheet.Sheet.Name = iProperties.Value(modelName, "Project", "Description
any help would be great
Darren
MechMachineMan
SyntaxEditor Code Snippet
For Each oSheet In ThisApplication.ActiveDocument.Sheets
    If oSheet.DrawingViews.Count = 0
         'Next Sheet
    Else
        oModelDoc = oSheet.DrawingViews.Item(1).ReferencedDocumentDescriptor.ReferencedDocument
        oProject = oModelDoc.PropertySets("Design Tracking Properties")("Project").Value
        If oProject <> ""
            oSheet.Name = oProject
        Else
            oSheet.Name = "xxx-NoProject"
Next
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
darrenwilliams
Hi
Thanks for the quick reply on this
This worked but put the project file as the sheet name i wanted to have the description of the parts as there will be different parts on each sheet
Darren
MechMachineMan
I had misread your first code and saw project instead of description... Don't know why inventor words the property sets differently for iLogic... Smiley Indifferent
Also, for future reference:
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
         'Next Sheet
    Else
        oDescription = oModelDoc.PropertySets("Design Tracking Properties")("Description").Value
        If oDescription <> ""
oSheet.Name = oDescription
Else
oSheet.Name = "xxx-NoDescription"
Next
Justin K
darrenwilliams
Thanks very much this worked great
