multi select sub parts
is it possible to multi select subparts in assembly using vba?
Vladimir.Ananyev
You may add any number of components to the select set using TopAssemblyDocument.SelectSet.Select(...) method. The sample "Navigation between browser and data" in the Inventor API Help could be useful as well.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
