put a drawing view name to prompted entry symbol
Message 1 of 9
Hi!
I use a CommandManager.Pick command to select my drawing view and i want to put information of this view to a prompted entry in my sketched symbols, i have many same symbols in my page and i want to put a different description for each symblos but with a same prompted entry name, ex.: <NAME>
Thanks for your help!
Replies (8)
Message 2 of 9
Stakin
Please Upload a sample pic,it is not Very Clear
Message 3 of 9
Message 4 of 9
Does anyone have code for a sketch symbol to be entered/created under a view once it has been created on a sheet.
I have a custom view label since the standard inventor design cannot be modified.
Cheers,
Message 5 of 9
xiaodong_liang
Autodesk Support
Autodesk Support
I wrote an iLogic code as below. Hope it helps. Please refer to the attached fig on how I defined the sketched symbol.
    Dim doc as DrawingDocument
    doc = ThisApplication.ActiveDocument
	Dim oObj As Object
	oObj = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter,"Select a view:")
	If oObj Is Nothing Then
	Else
	     Dim viewName As String = oObj.Name
		 Dim oNewResultText
		 oNewResultText = viewName + "other description"
		 Dim oPromptText  As TextBox
		 ' assume the name of sketched symbol definition is
		 ' "MySymbol"
		 Dim oSSD As SketchedSymbolDefinition
		 oSSD = doc.SketchedSymbolDefinitions("MySymbol")
		 '' search the prompt textbox in definition
		 Dim oEachText As TextBox
		 Dim I
		 For I = 1 To oSSD.Sketch.TextBoxes.Count
          oEachText = oSSD.Sketch.TextBoxes(I)
          If (oEachText.Text = "MY_PROMPT") Then
            ' found the prompt text we want to copy
              oPromptText = oEachText
            Exit For
        Next I
		'change the result text of the SketchedSymbol
		Dim oSS As SketchedSymbol
		For Each oSS In doc.ActiveSheet.SketchedSymbols
		   If oSS.Definition.Name = "MySymbol" Then
		      MsgBox(oNewResultText)
		       oSS.SetPromptResultText(oEachText,oNewResultText)
		Next
Message 6 of 9
 Thanks for your time Xiaodong Liang
 work great 🙂
Message 7 of 9
and if i want to change only the selected view sketched symblos and not all in the sheet?
Message 8 of 9
my test, but dont work 😞
Parameter.Quiet = True
Dim doc = ThisApplication.ActiveDocument
Dim entity = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select a drawing view.")
modelName = IO.Path.GetFileName(ActiveSheet.View(entity.Name).ModelDocument.FullFileName)
page = Right(ActiveSheet.Name, Len(ActiveSheet.Name) - 6)
iProperties.Value("Custom", "dossier du part") = (Left(modelName,11))
iProperties.Value("Custom", "dossier du projet")= (Right(ThisDoc.Path,11))
DETAIL1 = InputBox("NUMÉRO DU TITRE?", "TITRE", "Default Entry")
Dim viewName As String = entity.Name
Dim oNewResultText2
oNewResultText2 = ActiveSheet.View(entity.Name).ScaleString
oSSD = doc.SketchedSymbolDefinitions("TITRE1 DETAIL")
Dim oEachText2 As TextBox
oEachText2 = oSSD.Sketch.TextBoxes
If (oEachText2.Text = "test") Then
oSS.SetPromptResultText(oEachText2,oNewResultText2)
Message 9 of 9
Tried the code also, it works nice! Could this also be run with the same yield, but also reading a view's Page Number? Also, is there a way to pick what bubble this script could be applied to? I've a drawing set with several page refs, so adding one page takes up time to retype all 30+ field bubbles.
