Mouse Scroll on Combobox of VBA
Goodmorning,
to facilitate the compilation of all iporperties that we use in company, I made a little menù with Userform in Inventor's VBA.
In this menù I put a combobox with a several objects, now, if I use this combobox it appears the vertical scrollbar, but I can't scroll this list with mouse wheel.
Someone can help me?
No one can help me?
bradeneuropeArthur
My experience is that the mousescroll is not supported for that feature.
If needed you need to create your own object for that.
That is not easy.
If you start using vb.net than is will be much easier for you. If you are familiar with vba, then vb.net shouldn't be a problem.
Autodesk Software: Inventor Professional 2018 | Vault Professional 2018 | Autocad Mechanical 2018
Programming Skills: Vba | Vb.net (Add ins Vault / Inventor, Applications) | I-logic
Dimension Component! | Partlist Export! | Derive I-properties! | Vault Prompts Via API! | Vault Handbook/Manual!
Drawing Toggle Sheets! | Vault Defer Update!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
leipengshang
not yet,by searching some stuff about Excel vba .there could be.here is the code ,but in my program, it always crashed by running the program twice.
so could you give some advice?
===========here is the code in Model==========
Option Explicit
#If Win64 Then
Private Type POINTAPI
XY As LongLong
End Type
#Else
X As Long
Y As Long
End Type
#End If
Private Type MOUSEHOOKSTRUCT
Pt As POINTAPI
hWnd As Long
wHitTestCode As Long
dwExtraInfo As Long
End Type
#If VBA7 Then
Private Declare PtrSafe Function FindWindow Lib "user32" _
Alias "FindWindowA" ( _
ByVal lpClassName As String, _
ByVal lpWindowName As String) As Long ' not sure if this should be LongPtr
#If Win64 Then
Private Declare PtrSafe Function GetWindowLongPtr Lib "user32" _
Alias "GetWindowLongPtrA" ( _
ByVal hWnd As LongPtr, _
ByVal nIndex As Long) As LongPtr
#Else
Private Declare PtrSafe Function GetWindowLong Lib "user32" _
Alias "GetWindowLongA" ( _
#End If
Private Declare PtrSafe Function SetWindowsHookEx Lib "user32" _
Alias "SetWindowsHookExA" ( _
ByVal idHook As Long, _
ByVal lpfn As LongPtr, _
ByVal hmod As LongPtr, _
ByVal dwThreadId As Long) As LongPtr
Private Declare PtrSafe Function CallNextHookEx Lib "user32" ( _
ByVal hHook As LongPtr, _
ByVal nCode As Long, _
ByVal wParam As LongPtr, _
lParam As Any) As LongPtr
Private Declare PtrSafe Function UnhookWindowsHookEx Lib "user32" ( _
ByVal hHook As LongPtr) As LongPtr ' MAYBE Long
'Private Declare PtrSafe Function PostMessage Lib "user32.dll" _
' Alias "PostMessageA" ( _
' ByVal hwnd As LongPtr, _
' ByVal wMsg As Long, _
' ByVal wParam As LongPtr, _
' ByVal lParam As LongPtr) As LongPtr ' MAYBE Long
#If Win64 Then
Private Declare PtrSafe Function WindowFromPoint Lib "user32" ( _
ByVal Point As LongLong) As LongPtr '
#Else
ByVal xPoint As Long, _
ByVal yPoint As Long) As LongPtr '
#End If
Private Declare PtrSafe Function GetCursorPos Lib "user32" ( _
ByRef lpPoint As POINTAPI) As LongPtr 'MAYBE Long
#Else
Private Declare Function FindWindow Lib "user32" _
Private Declare Function GetWindowLong Lib "user32.dll" _
ByVal hWnd As Long, _
Private Declare Function SetWindowsHookEx Lib "user32" _
ByVal lpfn As Long, _
ByVal hmod As Long, _
Private Declare Function CallNextHookEx Lib "user32" ( _
ByVal hHook As Long, _
ByVal wParam As Long, _
Private Declare Function UnhookWindowsHookEx Lib "user32" ( _
ByVal hHook As Long) As Long
'Private Declare Function PostMessage Lib "user32.dll" _
' ByVal hwnd As Long, _
' ByVal wParam As Long, _
' ByVal lParam As Long) As Long
Private Declare Function WindowFromPoint Lib "user32" ( _
Private Declare Function GetCursorPos Lib "user32.dll" ( _
#End If
Private Const WH_MOUSE_LL As Long = 14
Private Const WM_MOUSEWHEEL As Long = &H20A
Private Const HC_ACTION As Long = 0
Private Const GWL_HINSTANCE As Long = (-6)
'Private Const WM_KEYDOWN As Long = &H100
'Private Const WM_KEYUP As Long = &H101
'Private Const VK_UP As Long = &H26
'Private Const VK_DOWN As Long = &H28
'Private Const WM_LBUTTONDOWN As Long = &H201
Dim n As Long
Private mCtl As Object
Private mbHook As Boolean
#If VBA7 Then
Private mLngMouseHook As LongPtr
Private mListBoxHwnd As LongPtr
#Else
#End If
Sub HookListBoxScroll(frm As Object, ctl As Object)
Dim tPT As POINTAPI
#If VBA7 Then
Dim lngAppInst As LongPtr
Dim hwndUnderCursor As LongPtr
#Else
#End If
GetCursorPos tPT
#If Win64 Then
hwndUnderCursor = WindowFromPoint(tPT.XY)
#Else
hwndUnderCursor = WindowFromPoint(tPT.X, tPT.Y)
#End If
If TypeOf ctl Is UserForm Then
If Not frm Is ctl Then
ctl.SetFocus
Else
If Not frm.ActiveControl Is ctl Then
ctl.SetFocus
If mListBoxHwnd <> hwndUnderCursor Then
UnhookListBoxScroll
Set mCtl = ctl
mListBoxHwnd = hwndUnderCursor
#If Win64 Then
lngAppInst = GetWindowLongPtr(mListBoxHwnd, GWL_HINSTANCE)
#Else
lngAppInst = GetWindowLong(mListBoxHwnd, GWL_HINSTANCE)
#End If
' PostMessage mListBoxHwnd, WM_LBUTTONDOWN, 0&, 0&
If Not mbHook Then
mLngMouseHook = SetWindowsHookEx( _
WH_MOUSE_LL, AddressOf MouseProc, lngAppInst, 0)
mbHook = mLngMouseHook <> 0
End Sub
Sub UnhookListBoxScroll()
If mbHook Then
Set mCtl = Nothing
UnhookWindowsHookEx mLngMouseHook
mLngMouseHook = 0
mListBoxHwnd = 0
mbHook = False
End Sub
#If VBA7 Then
Private Function MouseProc( _
ByVal nCode As Long, ByVal wParam As Long, _
ByRef lParam As MOUSEHOOKSTRUCT) As LongPtr
Dim idx As Long
On Error GoTo errH
If (nCode = HC_ACTION) Then
#If Win64 Then
If WindowFromPoint(lParam.Pt.XY) = mListBoxHwnd Then
If wParam = WM_MOUSEWHEEL Then
MouseProc = True
' If lParam.hWnd > 0 Then
' postMessage mListBoxHwnd, WM_KEYDOWN, VK_UP, 0
' Else
' postMessage mListBoxHwnd, WM_KEYDOWN, VK_DOWN, 0
' End If
' postMessage mListBoxHwnd, WM_KEYUP, VK_UP, 0
If TypeOf mCtl Is Frame Then
If lParam.hWnd > 0 Then idx = -10 Else idx = 10
idx = idx + mCtl.ScrollTop
If idx >= 0 And idx < ((mCtl.ScrollHeight - mCtl.Height) + 17.25) Then
mCtl.ScrollTop = idx
ElseIf TypeOf mCtl Is UserForm Then
Else
If lParam.hWnd > 0 Then idx = -1 Else idx = 1
idx = idx + mCtl.ListIndex
If idx >= 0 Then mCtl.ListIndex = idx
Exit Function
Else
UnhookListBoxScroll
#Else
If WindowFromPoint(lParam.Pt.X, lParam.Pt.Y) = mListBoxHwnd Then
MouseProc = True
' Else
' End If
Else
Exit Function
Else
UnhookListBoxScroll
#End If
MouseProc = CallNextHookEx( _
mLngMouseHook, nCode, wParam, ByVal lParam)
Exit Function
errH:
UnhookListBoxScroll
End Function
#Else
Dim idx As Long
On Error GoTo errH
MouseProc = True
' Else
' End If
Else
Exit Function
Else
UnhookListBoxScroll
Exit Function
errH:
UnhookListBoxScroll
End Function
#End If
============here is the code in form ===========
'Private Sub ComboBox1_MouseMove(ByVal Button As Integer, ByVal Shift As Integer, _
' ByVal X As Single, ByVal Y As Single)
'If Not Me.ActiveControl Is Me.ComboBox1 Then
' Me.ComboBox1.SetFocus
'End If
'Call HookListBoxScroll(Me, Me.ComboBox1)
'End Sub
leipengshang
hi guys ,finally i found an amazing code on GitHub,here is the link.
https://github.com/cristianbuse/VBA-UserForm-MouseScroll
the source code obtain MIT license.
have attention,please: it does only  work in model form.and do not support modeless form.
also it suport listview, combox treeview.
cristian.buseEP8JP
Community Visitor
Community Visitor
For anyone interested, the repository VBA-UserForm-MouseScroll now supports Modeless and Modal forms
