Modifying a Cylinder using Inventor API C#
lokit.khemka
lokit.khemka
I have the following code for obtaining the cylindrical faces in the open geometry. I want to modify the radius of the cylinder. How should I proceed with this?
 public static void HoleList(Inventor.Application mApplication)
            PartDocument doc = (PartDocument)mApplication.ActiveDocument;
            PartComponentDefinition PartCompDef = doc.ComponentDefinition;
            SurfaceBody body = PartCompDef.SurfaceBodies[1];
            int holeCount = 0;
            int count = body.Faces.Count;
            foreach (Face face in body.Faces)
                if (face.SurfaceType == SurfaceTypeEnum.kCylinderSurface)
                    holeCount++;
                    Cylinder cylinder = (Cylinder)face.Geometry;
                    double ddepth = 0.0;
                    if (cylinder.AxisVector.Z == 1 || cylinder.AxisVector.Z == -1)
                        ddepth = System.Math.Abs(System.Math.Abs(face.Vertices[1].Point.Z) - System.Math.Abs(face.Vertices[2].Point.Z)) * 10;
                    else if (cylinder.AxisVector.Y == 1)
                        ddepth = System.Math.Abs(System.Math.Abs(face.Vertices[1].Point.Y) - System.Math.Abs(face.Vertices[2].Point.Y)) * 10;
                    else if (cylinder.AxisVector.X == 1)
                        ddepth = System.Math.Abs(System.Math.Abs(face.Vertices[1].Point.X) - System.Math.Abs(face.Vertices[2].Point.X)) * 10;
                    double diameter = 2 * cylinder.Radius;
                    Console.WriteLine("Diameter: " + cylinder.Radius * 2 * 10 + " mm" + "\t" + "Depth: " + ddepth + " mm");
                    foreach(Edge edge in face.Edges)
                        Console.WriteLine(edge.StartVertex.Point.X + " " + edge.StartVertex.Point.Y + " " + edge.StartVertex.Point.Z);
                        Console.WriteLine(edge.StopVertex.Point.X + " " + edge.StopVertex.Point.Y + " " + edge.StopVertex.Point.Z);
Any help will be greatly appreciated. Thank you.
Michael.Navara
You can't modify surface body directly in this way, but you can use ThickenFeature for this.
lokit.khemka
Hi. Can you provide a simple code example for this? I am new to this and I am unable to get ThickenFeature to work with the code.
Michael.Navara
This is simple iLogic sample how to create ThicknessFeature from all cylindrical faces
Sub Main()
    Dim part As PartDocument = ThisDoc.Document
    Dim partDef As PartComponentDefinition = part.ComponentDefinition
    'Iterate all faces in first surface body
    For Each face As Face In partDef.SurfaceBodies(1).Faces
        'Check if face is cylindrical face
        Dim cylinder As Cylinder = TryCast(face.Geometry, Cylinder)
        If cylinder Is Nothing Then Continue For
        'Get radius for future use. Not used yet
        Dim radius As Double = cylinder.Radius
        'Build face collection for each face
        Dim faceCollection As FaceCollection = ThisApplication.TransientObjects.CreateFaceCollection()
        faceCollection.Add(face)
        'Set offset/thickness distance. It can depend on current radius
        Dim distance As Double = 0.1 ' 1 mm
        'Create thickness feature
        Dim thicknessFeature = partDef.Features.ThickenFeatures.Add(
            faceCollection,
            distance,
            PartFeatureExtentDirectionEnum.kPositiveExtentDirection,
            PartFeatureOperationEnum.kJoinOperation,
            False)
    Next
End Sub
