How to get the Inventor OccurrencePatternProxys from a sub assembly?
jaka73LU2
jaka73LU2
I am treversing an assembly and are trying to delete, hide, and suppress components. I have no problem with the components on the top level assembly (main assembly), but I have a problem with the lower level components, specificly patterns.
I kind of figured out that if I wanted to delete, hide or suppress lower level components I need a proxy object. That is easy for regular components that are of the type componentOccurrence. I get those throu the property SubOccurrences on the specified assembly.
But I can't figure out how to get the proxys of the type occurrencePattern. There seams to be no property for those, or any other way for searching for them.
Andrii_Humeniuk
Hi @jaka73LU2 . Wrote for you an example of obtaining all patterns (in the main assembly and subassemblies).
Private Sub Main()
	Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
	Call GetAllPatterns(oDef.OccurrencePatterns, oDoc.DisplayName)
	Call GetAllOccs(oDef.Occurrences)
End Sub
Private Sub GetAllOccs(oOccs As ComponentOccurrences)
	For Each oOcc As ComponentOccurrence In oOccs
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
			Dim oOccDef As AssemblyComponentDefinition = oOcc.Definition
			Call GetAllPatterns(oOccDef.OccurrencePatterns, oOcc.Name)
			If oOcc.SubOccurrences Is Nothing Then Continue For
			If oOcc.SubOccurrences.Count <> 0 Then
				Call GetAllOccs(oOcc.SubOccurrences)
	Next
End Sub
Private Function GetAllPatterns(oOccsPatt As OccurrencePatterns, sNameParent As String)
	For Each oOccPatt As OccurrencePattern In oOccsPatt
		MessageBox.Show(oOccPatt.Name, sNameParent)
	Next
End Function
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
jaka73LU2
I already tryed that but thought that it was not the right way, because the object I get back does not react to anything I would expect it to react to.
It does not react to visibility, suppression or adding it to selectSet. Example:
occPatt.Visibility = False
occPatt.Suppression()
This.Application.ActiveDocument.SelectSet.Select(occPatt)
When I try visibility it goes throo without an error, but nothing happens.
When I try suppress it gives error: Public member 'Suppress' on type 'RectangularOccurrencePattern' not found.
When I try SelectSet.Select I get an error: The parameter is incorect
Andrii_Humeniuk
Hi @jaka73LU2 . The visibility and suppression functions work perfectly, but SelectSet throws an error when trying to select items in a subassembly.
Private Sub Main()
	Dim oColl As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
	Call GetAllPatterns(oDef.OccurrencePatterns, oColl)
	Call GetAllOccs(oDef.Occurrences, oColl)
'	If oColl Is Nothing Then Exit Sub
'	Call oDoc.SelectSet.SelectMultiple(oColl)
'	oDoc.Rebuild()
'	oDoc.Update()
End Sub
Private Sub GetAllOccs(oOccs As ComponentOccurrences, ByRef oColl As ObjectCollection)
		If oOcc.Suppressed Then Continue For
			Dim oOccDoc As AssemblyDocument = oOccDef.Document
			If oOccDef.OccurrencePatterns.Count > 0 Then Call GetAllPatterns(oOccDef.OccurrencePatterns, oColl)
				Call GetAllOccs(oOcc.SubOccurrences, oColl)
	Next
End Sub
Private Function GetAllPatterns(oOccsPatt As OccurrencePatterns, ByRef oColl As ObjectCollection)
		' Work with visible
		oOccPatt.Visible = False
		MessageBox.Show(oOccPatt.Name & " - Visible", oOccPatt.Parent.Document.DisplayName)
		oOccPatt.Visible = True
		' Work with suppress
		oOccPatt.Suppress(True)
		MessageBox.Show(oOccPatt.Name & " - Suppress", oOccPatt.Parent.Document.DisplayName)
		oOccPatt.Unsuppress()
		'Select patterns
		oColl.Add(oOccPatt)
	Next
End Function
Also an example of working with the components of the opening subassembly:
Private Sub Main()
	Call GetAllPatterns(oDef.OccurrencePatterns)
End Sub
			if oOccDef.OccurrencePatterns.Count > 0 then Call GetAllPatterns(oOccDef.OccurrencePatterns, oOcc)
	Next
End Sub
Private Function GetAllPatterns(oOccsPatt As OccurrencePatterns, Optional oOcc As ComponentOccurrence = Nothing)
	If oOcc IsNot Nothing Then oOcc.Edit()
		MessageBox.Show(oOccPatt.Name, oOccPatt.Parent.Document.DisplayName)
	Next
	If oOcc IsNot Nothing Then oOcc.ExitEdit(ExitTypeEnum.kExitToParent)
End Function
jaka73LU2
I copied and pasted your code, but i am getting the same result.I would like to mention that I am making an AddIn so I slightly had to correct the code so a button is triggering the function.
Private Sub Button_test_Click(sender As Object, e As EventArgs) Handles Button_test.Click
        Try
            Dim oDoc As AssemblyDocument = g_inventorApplication.ActiveDocument
            Dim oColl As ObjectCollection = g_inventorApplication.TransientObjects.CreateObjectCollection
            For Each obj In oColl
                PrintToLog(obj.Name)
            Next
            'oDoc.Rebuild()
            'oDoc.Update()
        Catch ex As Exception
            MsgBox(ex.ToString())
        End Try
    End Sub
            oColl.Add(oOcc)
        Next
    End Sub
            ' Work with visible
            'Select patterns
            oColl.Add(oOccPatt)
        Next
    End Function
If I leave the line where it should suppress the patterns it gives an error: Public member 'Suppress' on type 'RectangularOccurrencePattern' not found.
If I comment out that line it gives an error at the 'SelectSet.SelectMultiple' where it gives an error: The parameter is incorrect.
The visibility line is ignored every time.
I need to point out that this problem persists only on lower level patterns. If I only look for top level patterns it works fine as expected.
