Variable in .Item property? Is it possible?
tm21915
tm21915
Is it possible to use variable when calling Item? I am getting Error "Expecting object to be local"
DO you maybe know how to solve this? Help would be really valuable
Dim patternName As String = Nothing
patternName = baseNamePattern & ":" & currentIndexPattern.ToString()
oDoc = ThisDoc.Document
Dim oPattern As RectangularOccurrencePattern = oDoc.ComponentDefinition.OccurrencePatterns.Item(patternName)
Andrii_Humeniuk
Hi @tm21915 . Yes, you can. Check whether the name of the pattern was entered correctly.
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oPattern As RectangularOccurrencePattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("Component Pattern 1:1")
MessageBox.Show(oPattern.Name, "Title")
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
tm21915
Aha thank you for reply, but in this case I am just entering string, the name of the pattern, as I understand
what I would like to do is call pattern name that variable is holding in this case variable patternName. Is that possible?
WCrihfield
Hi @tm21915.  Here is the official online help page for that specific item in question.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=OccurrencePatterns_Item
The Item property of the OccurrencePatterns API object will accept either an Integer that represents the index of the item, or a String, representing the name of the item.  But if no item can be found with the specified index number or name, then it will throw an error.  As suggested before, you may simply have to make sure that the name you are trying to supply there is correct first.  Usually something simple like a MsgBox(), or MessageBox.Show(), or Logger.Info() line is sufficient to inform you about what the code has encountered at that point in the code.  We may have to see the whole code to be a bit more sure about what the problem might be, if the correct name is being supplied there.
For instance, we can't tell what 'baseNamePattern' or 'currentIndexPattern' represent in your code, because they are not fully defined within that bit of code.  And the 'ThisDoc' reference might possibly be pointing to the wrong document, if we were to see the whole code, especially if it was being used within a loop of other referenced documents in a much larger code.
Wesley Crihfield
(Not an Autodesk Employee)
tm21915
Thank you for your response and help. The problem was, since it is used in loop, variable that wasn't defined right.
Thank you a lot for your help
