Model States Blowing Up iLogic Rule
chrisw01a
chrisw01a
I cannot figure out why this is creating an error.  It only happens when I add a model state to part 22222-801.ipt.  Even if it is not active, it still blows up at "flag to export" message box.  Run the rule from the assembly 22222-080.iam to cause the error.
Any help greatly appreciated!
Curtis_Waguespack
Hi @chrisw01a ,
I didn't look at your files, but I suspect these are old files that had LOD and have been migrated to 2022 and model states?
If so, you might try deleting the former LOD ( now model state ) and recreating it from scratch, and/or looking at the solution at this link.
Inventor 2022 Help | The Component.IsActive function in a delegated BOM model state does not update ...
I hope this helps.
Curtis
chrisw01a
Thanks for the reply.  I already removed the LOD code.  I'll read the article and see what I can find.
chrisw01a
I don't think the Component.IsActive issue is related to this.
The error occurs at the "ExposedAsProperty = True"
'if sheet metal part, get thickness and create custom iProperty
					If oCompDef.Type = ObjectTypeEnum.kSheetMetalComponentDefinitionObject Then
						Dim oParam As Inventor.Parameter = oCompDef.Parameters.Item("Thickness")
							If oParam IsNot Nothing Then
							MessageBox.Show("Flag to export")
							'Flag to export (creates custom iProperty)
							oParam.ExposedAsProperty = True
							MessageBox.Show("Pause-2")
							End If
					End If
