Ilogic nested list within multi value parameter
jamie.nelson.cubex
jamie.nelson.cubex
I am having trouble getting an Ilogic rule to work. I have to change two measurements on a headbox based on the length of another member (this member has two alternatives and the headbox changes size differently based on the member type).
A screenshot of the table is attached.
I have created a Muli Value Parameter for both Screws and Pipes. I think I now need to insert a nested list so that the headbox changes size based on what multi-value is selected and also the length of the member.
Curtis_Waguespack
Hi @jamie.nelson.cubex
If I understand correctly you would use the "SetList" method to update the Screws and Pipes lists on the fly.
See this example where a parameter called Color is used to update the lists called Name and Size.
I hope this helps.
Curtis
If Color = "Red" Then
	MultiValue.SetList("Size", 0.5, 0.75, 0.95, 1.25)
	MultiValue.SetList("Name", "Bob", "Lisa", "Carl", "Sally")
Else If Color = "Green" Then
	MultiValue.SetList("Size", 0.5, 0.75, 0.95)
	MultiValue.SetList("Name", "Bob", "Lisa", "Carl")
Else
	MultiValue.SetList("Size", 0.5, 0.75)
	MultiValue.SetList("Name", "Bob", "Lisa")
jamie.nelson.cubex
Hi @Curtis_Waguespack,
I am not quite sure that will solve my issue. I need to be able to select the guide type (Bolt or Pipe) and insert the dimensions (which is not a setlist) . The SO_height dimension changes the size of the headbox. The bigger the SO_height the bigger the headbox, however, the headbox sizes increase at different intervals depending on the fixing type.
This is the rule I have created, I know that I can not have "If" statements without an "End If". Can you advised on the correct code?
If bolt_or_pipe_fabric_fixing = "Bolt" Then
	If SO_height <=3500
	headbox_width = 180
	headbox_height = 180
Else If SO_height >3500.01 AndAlso SO_height <5000
	headbox_width = 200
	headbox_height = 200
Else If SO_height<=5000.01 AndAlso SO_height<6500
	headbox_width = 220
	headbox_height = 220
Else If SO_height <=6500.01 AndAlso SO_height <7500
	headbox_width = 240
	headbox_height = 240
Else If SO_height <= 7500.01
	MessageBox.Show("Pipe Guides Required At This Size", "Too Large", MessageBoxButtons.OK)
If bolt_or_pipe_fabric_fixing = "Pipe" Then
	If SO_height <=4500
	headbox_width = 180
Else If SO_height >4500.01 AndAlso SO_height <6500
	headbox_width = 200
Else If SO_height <=6500.01 AndAlso SO_height <8000
	headbox_width = 220
Else If SO_height <=8000.01 AndAlso SO_height <10000
	headbox_width = 220
Else If SO_height <= 10000.01
	MessageBox.Show("Curtains Drop Too Large, This Can Not Be Supplied", "Too Large", MessageBoxButtons.OK)
