MOD Operator Syntax
MOD Operator Syntax
brad.jackson
MOD Operator Syntax
brad.jackson
Can anyone give me some examples of how to set up the syntax for the MOD Operator in iLogic?
As an example, I would hope to get the remainder of a length divided by a set value of 95".
120.4375" / 95" = 1.xxx-xxxxxxxx
I would like to know if and how I might use the MOD operator in the iLogic code to get the remainder rounded to the nearest 16th (which in this case should be 25.4375").
I have used the % in the parameters to accomplish this in the past, but I am not sure how to set it up in code.
J-Camper
Here is a sample:
Dim inputVar As Double = 120.4375 in
Dim TOL As Double = 1 in  / 16 ul
Dim MODvalue As Double = 95 in
Dim Output1 As Double = Math.Round((inputVar Mod MODvalue) / TOL) * TOL
Logger.Trace(Output1)
brad.jackson
Thank you very much
