All In One Cabinet Design - Help on coding issue
Chirpyboy2060647
Chirpyboy2060647
Hey all, so I'm designing an iLogic cabinet that would be full customizable and going pretty well. I'm not the greatest coder but I can get by so far, and could use some guidance on a specific rule I want to make.
I have a rule right now that checks which side the Door_Direction, Left, Right, Both (double door). Then depending on the selection hides or shows the extrusions.
Well I want to add a drawer option, but the issue I run into is how to always hide the non-drawer left/right door cutout heights, but then which ever option is picked for the pull (left, right, both) would work for the new height locations.
I attached some screenshots to hopefully give a better idea what im trying to achieve.
CCarreiras
Let's try to understand what you mean...
If drawer True, suppress features A,B...etc (doors cutouts)... this works, right?
CCarreiras
TechInventor20
Is this what you are looking for?
Otherwise you need to explain it better.
Chirpyboy2060647
Sorry let me try to explain better as it probably wasn't clear enough.
So picture one has the circular hardware cutout up at the top/bottom. I have a rule to suppress based on which side you picked.
Now in the UI if they selected there is a drawer, a 2nd set of hardware cutouts would show up instead while suppressing the others. The new set of cutouts I want to also reference the 'DOOR_DIRECTION' param. so that if that changes it would change the new hinge locations when DRAWER = TRUE
Below is the coding I have so far, the last section was something I was trying and maybe will help make sense of what im trying to accomplish.
If DRAWER = "TRUE"
'New left hinge locations if drawer = true
Feature.IsActive("LHD_W-DRAWER") = True
'New right hinge locations if drawer = true"
Feature.IsActive("RHD_W-DRAWER") = True
'Supresses standard hinge cutouts if drawer = true'
Feature.IsActive("RHD") = False
Feature.IsActive("LHD") = False
'Start of the drawer extrusions and modifications in tree'
Feature.IsActive("DRAWER_START") = True
' ***Direct Edit9***
Feature.IsActive("Direct Edit9") = True
' ***Extrusion24***
Feature.IsActive("Extrusion24") = True
' ***Extrusion25***
Feature.IsActive("Extrusion25") = True
' ***Extrusion26***
Feature.IsActive("Extrusion26") = True
' ***Extrusion27***
Feature.IsActive("Extrusion27") = True
' ***Extrusion28***
Feature.IsActive("Extrusion28") = True
' ***Extrusion29***
Feature.IsActive("Extrusion29") = True
'last part of the drawer'
' ***Extrusion24***
Feature.IsActive("DRAWER_END") = True
' ***DRAWER_RAIL***
Feature.IsActive("DRAWER_RAIL") = True
Else If DRAWER = "FALSE"
Feature.IsActive("LHD_W-DRAWER") = False
Feature.IsActive("RHD_W-DRAWER") = False
' ***DRAWER_RAIL***
Feature.IsActive("DRAWER_RAIL") = False
Feature.IsActive("DRAWER_START") = False
Feature.IsActive("Direct Edit9") = False
' ***Extrusion24***
Feature.IsActive("Extrusion24") = False
' ***Extrusion25***
Feature.IsActive("Extrusion25") = False
' ***Extrusion26***
Feature.IsActive("Extrusion26") = False
' ***Extrusion27***
Feature.IsActive("Extrusion27") = False
' ***Extrusion28***
Feature.IsActive("Extrusion28") = False
' ***Extrusion29***
Feature.IsActive("Extrusion29") = False
' ***Extrusion24***
Feature.IsActive("DRAWER_END") = False
'This part was something i thought might work or what I think im trying to get to happen'
If DRAWER = "True"
DOOR_DIRECTION_DRAWER = DOOR_DIRECTION
Else If DRAWER = "False"
DOOR_DIRECTION_DRAWER = "NONE"
iLogicVb.UpdateWhenDone = True
TechInventor20
Just make the different variations.
If drawer = True then
else
'drawer = not shown
end if
if LHD_W-DRAWER = true and RHD_W-DRAWER = false then
' put code
else if LHD_W-DRAWER = false and RHD_W-DRAWER = true then
'put code
else if LHD_W-DRAWER = true and RHD_W-DRAWER = true then
'put code
end if
and you do this till you got all you're combinations.
