[iLogic] Create a Check Box List
JoãoASilva
JoãoASilva
Hello!
I want to create a Check Box List in iLogic, to complement a 200 lines rule I already have in place.
Pretty much like the "InputRadioBox", but each check returns a boolean for that option:
Before, our rule went thru all steps, including unnecessary ones.
Right now, we have message boxes with "Yes/No/Cancel" at different stages.
But I want to create a check list at the start, so I can check all parts that I want to run in that code.
I came across this article about CheckedListBox Class, but I can't quite implement it outright as is, and I don't know to much about .NET, only the iLogic language...
Any tips?
Thank you!
João Silva
Mechanical Engineer
A.Acheson
Here is the working form from that sample. It just needed a few tweeks. It hopefully will be a good starting point for you.
  1. Add Reference "System.Drawing"
  2. Add "Systems.Windows.Form" in front of Application
  3. Comment <StaThread()> , Unsure of this purpose maybe someone else can share their knowledge.
Option Explicit On
Option Strict On
Imports System.Drawing
AddReference "System.Drawing"
Imports System.Collections
Imports System.ComponentModel
Imports System.Windows.Forms
Imports System.Data
Imports System.IO
Namespace WindowsApplication1
    Public Class Form1
        Inherits System.Windows.Forms.Form
        Private WithEvents checkedListBox1 As System.Windows.Forms.CheckedListBox
        Private WithEvents textBox1 As System.Windows.Forms.TextBox
        Private WithEvents button1 As System.Windows.Forms.Button
        Private WithEvents button2 As System.Windows.Forms.Button
        Private WithEvents listBox1 As System.Windows.Forms.ListBox
        Private WithEvents button3 As System.Windows.Forms.Button
        Private components As System.ComponentModel.Container
        Public Sub New()
            InitializeComponent()
            ' Sets up the initial objects in the CheckedListBox.
            Dim myFruit As String() =  {"Apples", "Oranges", "Tomato"}
            checkedListBox1.Items.AddRange(myFruit)
            ' Changes the selection mode from double-click to single click.
            checkedListBox1.CheckOnClick = True
        End Sub
        Protected Overloads Overrides Sub Dispose(ByVal disposing As Boolean)
            If disposing Then
                If (components IsNot Nothing) Then
                    components.Dispose()
            MyBase.Dispose(disposing)
        End Sub
        Private Sub InitializeComponent()
            Me.components = New System.ComponentModel.Container()
            Me.textBox1 = New System.Windows.Forms.TextBox()
            Me.checkedListBox1 = New System.Windows.Forms.CheckedListBox()
            Me.listBox1 = New System.Windows.Forms.ListBox()
            Me.button1 = New System.Windows.Forms.Button()
            Me.button2 = New System.Windows.Forms.Button()
            Me.button3 = New System.Windows.Forms.Button()
            Me.textBox1.Location = New System.Drawing.Point(144, 64)
            Me.textBox1.Size = New System.Drawing.Size(128, 20)
            Me.textBox1.TabIndex = 1
            Me.checkedListBox1.Location = New System.Drawing.Point(16, 64)
            Me.checkedListBox1.Size = New System.Drawing.Size(120, 184)
            Me.checkedListBox1.TabIndex = 0
            Me.listBox1.Location = New System.Drawing.Point(408, 64)
            Me.listBox1.Size = New System.Drawing.Size(128, 186)
            Me.listBox1.TabIndex = 3
            Me.button1.Enabled = False
            Me.button1.Location = New System.Drawing.Point(144, 104)
            Me.button1.Size = New System.Drawing.Size(104, 32)
            Me.button1.TabIndex = 2
            Me.button1.Text = "Add Fruit"
            Me.button2.Enabled = False
            Me.button2.Location = New System.Drawing.Point(288, 64)
            Me.button2.Size = New System.Drawing.Size(104, 32)
            Me.button2.TabIndex = 2
            Me.button2.Text = "Show Order"
            Me.button3.Enabled = False
            Me.button3.Location = New System.Drawing.Point(288, 104)
            Me.button3.Size = New System.Drawing.Size(104, 32)
            Me.button3.TabIndex = 2
            Me.button3.Text = "Save Order"
            Me.ClientSize = New System.Drawing.Size(563, 273)
            Me.Controls.AddRange(New System.Windows.Forms.Control() {Me.listBox1, Me.button3, Me.button2, Me.button1, Me.textBox1, Me.checkedListBox1})
            Me.Text = "Fruit Order"
        End Sub
        'Unsure of it's use
        '<STAThread()> _
        Public Shared Sub Main()
            System.Windows.Forms.Application.Run(New Form1())
        End Sub
        ' Adds the string if the text box has data in it.
        Private Sub button1_Click(sender As Object, _
                e As System.EventArgs) Handles button1.Click
            If textBox1.Text <> "" Then
                If checkedListBox1.CheckedItems.Contains(textBox1.Text) = False Then
                    checkedListBox1.Items.Add(textBox1.Text, CheckState.Checked)
                textBox1.Text = ""
        End Sub
        ' Activates or deactivates the Add button.
        Private Sub textBox1_TextChanged(sender As Object, _
                e As System.EventArgs) Handles textBox1.TextChanged
            If textBox1.Text = "" Then
            Else
                button1.Enabled = True
        End Sub
        ' Moves the checked items from the CheckedListBox to the listBox.
        Private Sub button2_Click(sender As Object, _
                e As System.EventArgs) Handles button2.Click
            listBox1.Items.Clear()
            Dim i As Integer
            For i = 0 To checkedListBox1.CheckedItems.Count - 1
                listBox1.Items.Add(checkedListBox1.CheckedItems(i))
            Next i
            If listBox1.Items.Count > 0 Then
                button3.Enabled = True
        End Sub
        ' Activates the move button if there are checked items.
        Private Sub checkedListBox1_ItemCheck(sender As Object, _
                e As ItemCheckEventArgs) Handles checkedListBox1.ItemCheck
            If e.NewValue = CheckState.Unchecked Then
                If checkedListBox1.CheckedItems.Count = 1 Then
            Else
                button2.Enabled = True
        End Sub
        ' Saves the items to a file.
        Private Sub button3_Click(sender As Object, _
                e As System.EventArgs) Handles button3.Click
            ' Insert code to save a file.
            For Each index In checkedListBox1.CheckedIndices.Cast(Of Integer).ToArray()
                checkedListBox1.SetItemChecked(index, False)
            Next
        End Sub
    End Class
End Namespace 'WindowsApplication1
Regards
Alan
