Microsoft Visual Basic no longer installed
johan.degreef
Advisor Advisor
johan.degreef
When installing Inventor 2021 on a new PC, And wanted to add my ilogic code to the ribbon, using this method:
https://www.cadlinecommunity.co.uk/hc/en-us/articles/115000859309-Inventor-Run-iLogic-Rules-from-you...
seems no longer possible
https://knowledge.autodesk.com/support/inventor/downloads/caas/downloads/content/download-the-micros...
Is there another way to add buttons to my ribbon to activate iLogic rules?
Many Thanks, Johan
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
bradeneuropeArthur
Hi Johan,
@JelteDeJong  wrote an add in for this situations!
https://clintbrown.co.uk/2020/11/28/run-ilogic-rules-from-the-ribbon/
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
