Method to use "Select As Edges" from Sketches/Surfaces in drawings
sergio_duran
sergio_duran
Hi Everyone,
Do you know whether it's possible to use the option "Select As Edges" when you right click on a Part Sketch or Surface in a drawing (see attached images - Right Click menus) using API?
Thanks!
bshbsh
I'm not sure if and how it works, but there's an internal command for that: SelectAsEdgesCtxCmd. I guess the node has to be selected first, but never tried.
ThisApplication.CommandManager.ControlDefinitions.Item("SelectAsEdgesCtxCmd").Execute
