problem of display dimension cotation
sylvmig
sylvmig
Since several update, we couldnt display dimensionnal  cotation : you select the two lines for the dimension cotation, inventor display the cotation, you move the cotation and when you valid, inventor doesnt display the cotation !
and i have the same problem with the line and arrow for assign a text or a nomenclature number affectation...
it s really frustating with a new version that basic cotation function doesn't display correctly !
https://knowledge.autodesk.com/community/screencast/0ab971de-e3e1-4b28-9756-dd03463101ce
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @sylvmig,
Current issue is posted in wrong forum(Inventor Customization forum)
Can you please post it in Inventor Forum using below link?
https://forums.autodesk.com/t5/inventor-forum/bd-p/78
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
