Measure the angle between the working plane of the assembly and the working plane of occurence
Hubert_Los
Hubert_Los
Hi All,
I would like measure the angle between the working plane of the assembly and the working plane of occurence
I can't use codes below
angle = Measure.Angle("componentName1", "Plane1", Assembly, "XY Plane")
Any ideas?
Hubert.
dalton98
I couldn't get the measure.angle tool to work. This is another way to do it, you have to create a geometry proxy for the plane inside the component.
Dim oAss As AssemblyDocument = ThisApplication.ActiveDocument
Dim XYplane As WorkPlane = oAss.ComponentDefinition.WorkPlanes.Item("XY Plane")
Dim oOcc As ComponentOccurrence
oOcc = oAss.ComponentDefinition.Occurrences.ItemByName("component1:1")
Dim Plane1 As WorkPlane = oOcc.Definition.WorkPlanes.Item("Plane1")
oOcc.CreateGeometryProxy(Plane1, Plane1)
angle = ThisApplication.MeasureTools.GetAngle(XYplane, Plane1) * 180 / PI
MessageBox.Show(angle)
Hubert_Los
It works, thank you.
