Material Updating Incorrectly
gbaker7NQNF
gbaker7NQNF
j = List.Count
'j = 18
For i = 2 To j+1
	sNewName = GoExcel.CellValue("B" & i)
	doc.SaveAs(oooFolder & GoExcel.CellValue("A" & i) & " " & sNewName & ".ipt", True)
	xDoc = ThisApplication.Documents.Open(oooFolder & GoExcel.CellValue("A" & i) & " " & sNewName & ".ipt")
	If GoExcel.CellValue("C" & i) = "ABS" Then
			iProperties.Material = "ABS Plastic"
	Else If GoExcel.CellValue("C" & i) = "Acrylic" Then
			iProperties.Material = "Polycarbonate, Clear"
	End If
	InventorVb.DocumentUpdate(True)
	Dim oPars As UserParameters = xDoc.ComponentDefinition.Parameters.UserParameters
	oPars.Item("width").Expression = "isolate(" & GoExcel.CellValue("G" & i) & ";in;in)"
	oPars.Item("height").Expression = "isolate(" & GoExcel.CellValue("F" & i) & ";in;in)"
	oPars.Item("thk").Expression = "isolate(" & GoExcel.CellValue("E" & i) & ";in;in)"
	xDoc.Save
	xDoc.Close(True)
	For k = 1 To GoExcel.CellValue("I" & i)
	oAssyDoc.ComponentDefinition.Occurrences.Add(oooFolder & GoExcel.CellValue("A" & i) & " " & sNewName & ".ipt", oPos)
	Next k
Next i
 I have this block of code which is used to generate parts based on a spreadsheet. One of my columns is a list of different materials. The pink section of my code is meant to read this column and update the material accordingly. My issue is: the first instance of a new material is set incorrectly, matching the previous material. The following instances are correct.
Here's an example:
The column for material reads as follows:
1. ABS
2. ABS
3. ABS
4. ABS
5. Acrylic
6. Acrylic
7. Acrylic
8. ABS
9. ABS
10. ABS
When the parts are created, part 1 will default to Polycarbonate (which the template file is set to initially), part 5 will be set to ABS, part 8 will be Polycarbonate, and the rest are correct.
If anyone knows what's going on please let me know!  Any help would be greatly appreciated!
A.Acheson
Hi @gbaker7NQNF
Because your using an ilogic snippet and the document is continuing to change you might be getting incorrect document targeting.
You can change the document material via API using the below code and research the syntax via API help.
Syntax
AssetName
Asset.Name() As String
PartDocument ActiveMaterial
PartDocument.ActiveMaterial() As Asset
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
    Dim assetLib As AssetLibrary  = ThisApplication.AssetLibraries.Item("Inventor Material Library")
	ThisApplication.ActiveMaterialLibrary = assetLib
    Dim MaterialName As String = "Gold"
    Try
	Dim localMaterial As MaterialAsset = oDoc.MaterialAssets.Item(MaterialName)
 	Catch
    Dim libMaterial As MaterialAsset = assetLib.MaterialAssets.Item(MaterialName)
	libMaterial.CopyTo(oDoc)
	End Try
	oDoc.ActiveMaterial = oDoc.MaterialAssets.Item(MaterialName)
Regards
Alan
