Export a DXF of every model state for a part?
claudio.ibarra
claudio.ibarra
I have a part for a label that's going on an engraver. It contains 3 lines of text. I'm using model states to generate every version of the label, and I want to make a DXF for each to give to the engraver operator.
Is it possible for an iLogic rule in a drawing to look at associated .ipt, iterate through each model state and create a DXF for each one?
Andrii_Humeniuk
Hello. I hope the following code will help you.
Sub Main
    Dim oDoc As Document = ThisApplication.ActiveDocument
	If TypeOf oDoc Is PartDocument Then
		Dim oPartDoc As PartDocument = oDoc
		Dim sActiveMS As String = oPartDoc.ModelStateName
		If TypeOf oPartDoc.ComponentDefinition Is SheetMetalComponentDefinition Then
			Dim oPartDef As SheetMetalComponentDefinition = oPartDoc.ComponentDefinition
			Dim sDirectName As String = System.IO.Path.GetDirectoryName(oDoc.FullDocumentName)
			Dim sNameDoc As String = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullDocumentName)
			Dim sNameAndPath As String = sDirectName & "\" & sNameDoc & ".dxf"
			'[Seting export DXF
			Dim sSetDXF As String = "FLAT PATTERN DXF?AcadVersion=R12&RebaseGeometry=True&SimplifySpline=True&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL&SplineToleranceDouble=0.01"
'			Dim sSetDXF As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE"
			For Each oMS As ModelState In oPartDef.ModelStates
				oMS.Activate()
				sNameAndPath = sDirectName & "\" & sNameDoc & " (" & oMS.Name & ")" & ".dxf"
				Dim oDataIO As DataIO = oPartDef.DataIO
				Call oDataIO.WriteDataToFile(sSetDXF, sNameAndPath)
			Next
			oPartDef.ModelStates.Item(sActiveMS).Activate()
		Else
			MessageBox.Show("Active document is not SheetMetalDocument!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
	Else
		MessageBox.Show("Active document is not PartDocument!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
claudio.ibarra
That worked, thank you!
I thought DXFs had to be made from a drawing, and I hadn't considered making it a sheet metal part.
diego_dorta
great rule thanks
is it possible to use the part number of each model state as dxf file name?
I think this is the string to modify:
but I can't find the way to catch the part number of the model state.
thank you
Andrii_Humeniuk
Hi @diego_dorta . Try this code:
Sub Main
			Dim sPartNumb, sNameAndPath As String
			'[Seting export DXF
				oMS.Activate()
				sPartNumb = oPartDoc.PropertySets("Design Tracking Properties")("Part Number").Value
				sNameAndPath = sDirectName & "\" & sPartNumb & ".dxf"
			Next
		Else
	Else
End Sub
diego_dorta
super
exactly what I was looking for!!
thank you very much
Jordon.Oldham
hi there!
sorry to tag onto this thread, but i am trying to do the same thing as above but none of the rules work for me.
I have several parts that each contain several that id like to auto export with their part codes as their file name.
any help will be greatly appreciated.
Jordon
