Material Library and changing appearances
NachoShaw
Advisor Advisor
NachoShaw
Hi
I use a material library and a separate appearance library. First, can I just use 1 file that has both material and appearance or is it best to have separate files?
Is there a handy code solution that can list all of the materials from my library (NachoMatLib) so that I can put it in a listbox?
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
bradeneuropeArthur
        ListView1.Items.Clear()
        Dim oapp As Inventor.Application
        oapp = _InvApp
        Dim oCurrentDoc As Document
        Dim oItem As ListViewItem ' ListItem
        Dim IM As Integer
        Dim IMMAX As Integer
        IMMAX = oapp.ActiveDocument.Materials.Count
        For IM = 1 To IMMAX
            oCurrentDoc = oapp.ActiveDocument
            Dim oDrawDoc As Document
            oDrawDoc = oapp.ActiveDocument
            'get the "Design Tracking Properties"
            Dim odrawInvDsgnTrcPrpPropSet As PropertySet
            odrawInvDsgnTrcPrpPropSet = oDrawDoc.PropertySets.Item("Design Tracking Properties")
            Dim odrawInvDsgnTrcPrpVolumePropset As [Property]
            odrawInvDsgnTrcPrpVolumePropset = odrawInvDsgnTrcPrpPropSet.Item(39)
            oItem = ListView1.Items.Add(oapp.ActiveDocument.Materials.Item(IM).Name)
        Next
or better you use a combobox:
        ComboBox1.Items.Clear()
        oapp = _InvApp
        Dim IM As Integer
        For IM = 1 To IMMAX
            'Set oApp = ThisApplication
            ComboBox1.Items.Add(oapp.ActiveDocument.Materials.Item(IM).Name.ToString)
        Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
NachoShaw
Hi
Thanks for the reply. This makes a list of materials in the active document whereas I need to get a full list of the materials in the current library.
I'm going to try it in a while 🙂
Nacho
bradeneuropeArthur
This is a list of the library. that are used by the document.
So they are not in the document yet....
Think this is still what you need.
regards,
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
NachoShaw
ok cool, appreciate it. Is there a method of getting the image path to the appearance also and the color (when no image is used)?
cheers
Nacho
