Mate Constraint solution type
anita_zhangBRAD8
anita_zhangBRAD8
Hi, experts. Is there any way I can make the solution type of mate constraint "aligned" instead of default to "undirected"?
According to the official documentation here: Inventor 2024 Help | MateConstraint Object | Autodesk, the solution type is read-only and there are no other properties/methods that allow me to change the solution type.
Here are my code to construct the the mate constraint:
	Dim mateCons As MateConstraint
	mateCons = asmDef.Constraints.AddMateConstraint(targetTemplateEdge, targetDuplicateEdge, 0)
	mateCons.Visible = True
	MsgBox(mateCons.SolutionType)
Thank you for the help!
Curtis_Waguespack
@anita_zhangBRAD8 , I think the syntax would be something like this ( untested):
mateCons = asmdef.Constraints.AddMateConstraint2(targetTemplateEdge, targetDuplicateEdge ,0,InferredTypeEnum.kInferredLine,InferredTypeEnum.kInferredLine, MateConstraintSolutionTypeEnum.kUndirectedSolutionType)
Hope that helps,
Curtis
anita_zhangBRAD8
That works! Thank you for the help!
