Export iPart members as STEP files using iLogic
tsoliya
Message 1 of 1
tsoliya
iLogic to direct export the iPart factory members as individual STEP files:
  • No need for VBA or to generate individual iPart members and then use Inventor Task Scheduler.
  • Tested in Inventor 2024
Customize the iLogic as needed:
  • Define output file location for the STEP files
  • STEP file names will be assigned as per the iPart member names
Dim PartDoc As PartDocument
Dim STEPTranslator As TranslatorAddIn
Dim TranslationContext As TranslationContext
Dim NameValueMap As NameValueMap
Dim DataMedium As DataMedium
Dim MemberName As String
' Get the current part document
PartDoc = ThisApplication.ActiveDocument
' Ensure the document is an iPart factory
If PartDoc.ComponentDefinition.IsiPartFactory Then
	' Get the STEP translator Add-In.
	STEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
	If STEPTranslator Is Nothing Then
		MsgBox("Could not access STEP translator.")
		Exit Sub
	' Create the necessary objects for translation
	TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
	NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	' Check if SaveCopyAs options are available
	If STEPTranslator.HasSaveCopyAsOptions(PartDoc, TranslationContext, NameValueMap) Then
		' Set application protocol >> 2 = AP 203 - Configuration Controlled Design | 3 = AP 214 - Automotive Design
		NameValueMap.Value("ApplicationProtocolType") = 3
		' Set the context type
		TranslationContext.Type = kFileBrowseIOMechanism
		' Loop through each row (iPart member) in the iPart factory
		For Each iPartTableRow In PartDoc.ComponentDefinition.iPartFactory.TableRows
			' Get the iPart member name and Activate it
			MemberName = iPartTableRow.MemberName
			iPart.ChangeRow("", MemberName)
			' Define the output file path and name (using the member name)
			DataMedium.FileName = "C:\Users\Public\Desktop\STEP\" & MemberName & ".step"
			' Perform the translation (export)
			Call STEPTranslator.SaveCopyAs(PartDoc, TranslationContext, NameValueMap, DataMedium)
		Next iPartTableRow
		MsgBox("STEP file exported successfully.")
	Else
		MsgBox("Could not export STEP file.")
Else
	MsgBox("The active document is not an iPart factory.")
Replies (0)
