I LOGIC code question
corey_danielson
Message 1 of 12
corey_danielson
I will explain this the best I can.
I am setting up some standard bolts, I would like to create a form where someone could select bolt size, (3/4-10)
Length (2,2 1/4, etc) and grade (Grade 5 or 8) This way they would not have the scroll through all the options when I have the one column with all the information.  This is part of what I have for now, this includes all bolt options 1/4 - 1"
If DescriptionBolt = "HEX BOLT 3/4-10 X 2 1/2 GR.5" Then
LENGTH = 2.5
THREADLENGTH = .75
SLOTPATTERN = 3
HEADTHICKNESS = .46875
DIAMETER = .75
HEX = 1.125
boltpartnumber = "HB-NC.75-10X2.5 GR5"
Feature.IsActive("Thread3") = True
Feature.ThreadDesignation("Thread3") = "3/4-10 UNC"
If DescriptionBolt = "HEX BOLT 3/4-16 X 2 1/2 GR.5" Then
LENGTH = 2.5
THREADLENGTH = .75
SLOTPATTERN = 3
DIAMETER = .75
HEX = 1.125
boltpartnumber = "HB-NC.75-16X2.5 GR5"
Feature.ThreadDesignation("Thread3") = "3/4-16 UNF"
Can do something like:
If DescriptionBolt = "HEX BOLT 3/4-10  and Length = Length and grade = grade then
BOLTDESCRIPTION = HEXBOLT 3/4-10 X "LENGTH" X "GRADE"
If I selected 3/4-10,  2 1/2, and Grade 5
 I would like the description to look like this - HEX HEAD BOLT 3/4-10 X 2 1/2 GR5
I would have 3 multi line parameters named DescriptionBolt, Length. and Grade
I need some help on setting this up to work. Did I explain this ok?
Thank you
Accepted solutions (3)
Replies (11)
Message 2 of 12
corey_danielson
this may explain better what I am trying to do
Message 3 of 12
Curtis_Waguespack
@corey_danielson , post your part file ( and mention what version of Inventor you are using) and I'm sure someone will take a look. As it is, I don't think there is not enough information to assist.
Message 4 of 12
corey_danielson
Inventor Professional 2022.1.1
This is the part I am trying to have a form
 You can see the forms I have in here. Form 2 is the one I would like to work as is. (Pick your bolt was the original try)
Does this help? Let me know what else you need. Thank you.
Message 5 of 12
Curtis_Waguespack
@corey_danielson , see this example. I feel like there is a more straight forward way to convert the fractional string into a decimal, but it didn't come to mind... maybe someone else will think of it.
In any case, this example works by splitting the fraction into a parts.
Hope that helps,
Curtis
If Parameter("BOLT_DESCRIPTION") = BOLT_DESCRIPTION Then
	iProperties.Value("Project", "Description") = BOLT_DESCRIPTION
	iProperties.Value("Project", "Part Number") = boltpartnumber
If Parameter("GRADE") = GR5 Then
	SLOTPATTERN = 3
ElseIf Parameter("GRADE") = GR8 Then
	SLOTPATTERN = 5
If DescriptionBolt = "HEX BOLT 1/4-20" Then
	oLength = BOLT_LENGTH
	If oLength.Contains("/") Then 'if the value has a forward slash, then convert to decimal
		'example: 3 1/4
		sArray = Split(BOLT_LENGTH, " ") 'split the string into parts using the space as the seperator
		Dim Int As Integer = sArray(0) 'example returns: 3
		Dim Fraction As String = sArray(1) 'example returns: 1/4
		sFractionArray = Split(Fraction, "/") 'split the remainer into parts using the / as the seperator
		'example returns: 1 and 4
		'	sFractionArray(0) , would be 1
		' 	sFractionArray(1)  , would be 4
		Dim Dbl As Double = sFractionArray(0) / sFractionArray(1) 'example returns 0.25
		oLength = Int + Dbl ' assembly the decimal, example returns 3.25
	LENGTH = oLength
	THREADLENGTH = .75
	SLOTPATTERN = SLOTPATTERN
	HEADTHICKNESS = .15625
	DIAMETER = .25
	HEX = .4375
	boltpartnumber = (DescriptionBolt) & "X" & (BOLT_LENGTH) & (GRADE)
	BOLT_DESCRIPTION = DescriptionBolt & " X " & BOLT_LENGTH & " " & GRADE
	Feature.ThreadDesignation("Thread3") = "1/4-20 UNC"
iLogicVb.UpdateWhenDone = True
Message 6 of 12
corey_danielson
Thank you VERY much, I can work with this. I cannot get it to switch between grade 5 and grade 8 now, but the length is working perfectly!
Message 7 of 12
Curtis_Waguespack
@corey_danielson , ahh I didn't look at grade before, but you can just move the iProps block down to the bottom as shown and remove the if/then as shown
	SLOTPATTERN = 3
	SLOTPATTERN = 5
		'example: 3 1/4
	LENGTH = oLength
	THREADLENGTH = .75
	DIAMETER = .25
	HEX = .4375
Message 8 of 12
corey_danielson
Any idea how to make the grade work? It was working earlier. I will keep looking at it as well. Can't tell you how much I appreciate your help. Thank you
Message 9 of 12
Curtis_Waguespack
The last example should fix the grade as far as updating the part number and description. Was there more to what Grade should do than updating those?
Message 10 of 12
corey_danielson
Curtis,
I just checked, the part number and description are updating correctly, my slot pattern isn't changing from 3 to 5.
Message 11 of 12
corey_danielson
I was originally going to have a part for each size bolt, this was how it was working. d13 was the slot pattern quantity
If
Parameter("DescriptionBolt") = DescriptionBolt Then iProperties.Value("Project", "Description") = DescriptionBolt iProperties.Value("Project", "Part Number") = boltpartnumber Parameter("HEADTHICKNESS") = .390625 Parameter("DIAMETER") = .625 Parameter("HEX") = .9375 End If If DescriptionBolt = "HEX BOLT <material> 5/8-11 X 2 1/2 GR.5" Then LENGTH = 2.5 THREADLENGTH = 1.25 d13 = 3 boltpartnumber = "HB-NC.625-11X2.5GR5" Feature.IsActive("Thread3") = True Feature.ThreadDesignation("Thread3") = "5/8-11 UNC" End If If DescriptionBolt = "HEX BOLT 5/8-11 X 2 1/2 GR.8" Then LENGTH = 2.5 THREADLENGTH = 1.25 d13 = 5 boltpartnumber = "HB-NC.625-11X2.5GR5" Feature.IsActive("Thread3") = True Feature.ThreadDesignation("Thread3") = "5/8-11 UNC" End If If DescriptionBolt = "HEX BOLT 5/8-18 X 2 1/2 GR.5" Then LENGTH = 2.5 THREADLENGTH = 1.25 d13 = 3 boltpartnumber = "HB-NF.625-18X2.5GR5" Feature.IsActive("Thread3") = True Feature.ThreadDesignation("Thread3") = "5/8-18 UNF"
Message 12 of 12
corey_danielson
Curtis,  I got it! it all works now. Slots change when i change the grade in my form
