Task Scheduler calling Addin.Activate
Bradley_PrattBCKXW
Bradley_PrattBCKXW
Hi everyone, running into an issue at the moment with the task scheduler. When the task scheduler runs any task it calls the addins Activate() method but this leads to some unexpected behaviour which we'd normally avoid with the silentOperation check but the task scheduler doesnt seem to count as a silentOperation. Has anyone else had a similar issue, or at least knows of a way to check if inventor was launched by the task scheduler?
bradeneuropeArthur
Could you please show us the code how you set the specific Inventor session as Silent?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
