Marking Menu - Macro Display Name
Is it possible to change the displayed name in the marking menu when using a macro as a command? It now displays the default macro name which is not as visually appealing.
Image for clarification
frederic.vandenplas
As far as i know, i never ever found some info to do this 😞
That's the main reason i jumped to .NET 😛
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
I suspected this but wanted to ask here just in case.
I don't know much about programming so I think .NET is too complicated for me at the moment. I just recently started to combine and put together already-made snippets in the VBA Editor.
Jon.Dean
Hi Michele,
What you want is not possible at the moment.
You could post a wish on the IdeaStation, if you get enough votes, it might become a feature.
Cheers
Jon.
Jon Dean
Hi Jon,
Then I know, thank you.
