Code to run only when form is open
Is there any way to check to see if a form is open, and if it is open, run some code? The setup is:
I have a form that is opened with a button in another form. When certain parameters are changed, rules are triggered and change some values. In order to speed up the processing time, I would like certain calculations to only run if the relevant form is open. Is this possible?
For Example:
iLogicForm.Show("Form 1")
 is a predefined command that exists. Is there a way to access information about the form already being open? All I really need is a Boolean true/false
bshbsh
You can check if the .Visible property of the userform is true or false. (At least in VBA, but I assume it's the same or similar in iLogic.)
I get the error 'Visible' is not a member of 'Autodesk.iLogic.Interfaces.IiLogicForm'.
when I try to run this:
If iLogicForm.Visible("Meter Creator") = True Then
    MsgBox("Visible")
So I created a workaround, where when clicking the button to launch the form, toggle a True/False parameter to true. Then, I created a button on the form to close it, that then toggles the true/false parameter to false.
