Mark parameters for Export
Jesper_S
Message 1 of 10
Jesper_S
Hi.
Is there a way using iLogic to mark renamed model parameters to be exported to custom iProperty?
I have a code that exports ALL parameters but i want to export just the parameters that Dont have "d" in the beginning of the name. (all model parameters as you all know are named d0, d1, d2 and so on).
//Jesper
//Jesper
Replies (9)
Message 2 of 10
Ktomberlin
You would use: Parameter.Param("YOURVALUE").ExposedAsProperty = True
for a single value. For a list of them you could do it several ways, build an array, a For statement (For Each oParam In )
Message 3 of 10
MechMachineMan
If oParameter.Name Like "d*"
'Do not export
Else
'Export
End if
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 10
Jesper_S
I have managed to export parameters with specific names and change the property format to what i want.
But i dont know how to get it to export all my named modelparameters.
Im very new to iLogic and how it works.
This is what i managed to put together.
SyntaxEditor Code Snippet
oParameter = Parameter.Param("Height")
If oParameter.Name Like "Height"
oParameter.ExposedAsProperty = True
Dim oFormat As CustomPropertyFormat
oFormat=oParameter.CustomPropertyFormat
oFormat.Units="mm"
oFormat.ShowUnitsString=False
'set to show/not show the unit string (use True to show)
'set to show/not show the trailing zeros (use True to show)
oFormat.ShowTrailingZeros = False
'set to show/not show the leading zeros (use True to show)
oFormat.ShowLeadingZeros = False
//Jesper
//Jesper
Message 5 of 10
MechMachineMan
Dim oCompDef As ComponentDefinition
Dim oParameter As Parameter
oCompDef = ThisApplication.ActiveDocument.ComponentDefinition
oModelP=oCompDef.Parameters.ModelParameters
For Each oParameter in oModelP
'If oParameter.Renamed=True
oParameter.ExposedAsProperty=True
'SVar.oList.Add(oParameter.Name)
'End If
Next
Justin K
Message 6 of 10
Jesper_S
Thanks. That worked like a charm.
But now my code that changes the Custom Property Format doesnt work and i dont know whats wrong.
Getting :
Error in rule: Rule2, in document: Part4
Object reference not set to an instance of an object.
Next
oFormat.Units="mm"
Whats wrong?
//Jesper
//Jesper
Message 7 of 10
MechMachineMan
First glance I can't see anything obvious. Put a message box in and move
it don't line by line, running code in between to do a manual debug.
Justin K
Message 8 of 10
Jesper_S
Next
'oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType'oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kZeroDecimalPlacePrecision'oFormat.Units="mm"'set to show/not show the unit string (use True to show)'oFormat.ShowUnitsString=False'set to show/not show the trailing zeros (use True to show)'oFormat.ShowTrailingZeros = False'set to show/not show the leading zeros (use True to show)'oFormat.ShowLeadingZeros = False
This works but as soon as i add one more line, doesnt matter witch one of the "oFormat" lines i get the error.
Error in rule: Rule2, in document: Part4.ipt
//Jesper
Message 9 of 10
MechMachineMan
Move all of the format stuff into the if statement; you can only format
parameters that are exposed.
Justin K
Message 10 of 10
Jesper_S
Many thanks. Worked.
oFormat.Units="mm"
Next
//Jesper
