Making solid Bodies in a part invisible in .idw
arnold.ogalo
arnold.ogalo
Hey Community,
I am using inventor 2020 to create an automated drawing for a parametric model. I was wondering if it is possible to turn off visibility of Solid Bodies in the drawing view using ilogic just the same way you would manually.
Thank you.
bradeneuropeArthur
how and when do you want to make them invisible?:
  • by selection in browser
  • by selection in view
  • by name
  • or else
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
arnold.ogalo
Hey Arthur,
So the picture above shows a drawing of a part. I have been able to show individual rings by creating 4 views and turning off the rings (solid Bodies) that I don't want shown in the view from the model tree. This is want I would like to replicate with ilogic.
My intention is to input the number of rings I want shown and the rest(Solid bodies) will be made invisible.
I believe this involves making invisible by name.
bradeneuropeArthur
you can do that even without coding, you know that?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
arnold.ogalo
So ideally I would suppress the features from the part file and hence not showing in the drawing. However, if I Unsuppressed these features from the part file they will reappear in all the views of the drawing which will require manually turning off the solid bodies from the views.
The purpose of the code is to let the drawing know that for each view I only want 1 solid body to show.
