Making plugin loaded for user automatically without entering plugin manager
jzarczynski
jzarczynski
I've been working on add-ons for Autodesk Inventor. I deploy them remotely to users' computers. After the initial restart of Inventor, users need to head over to the Add-In Manager, deselect the 'Blocked' option, and then tick the checkboxes for 'Loaded/Unloaded' and 'Load Automatically'.
Surprisingly, some users find these steps quite challenging. Is there a way to lift the block on the add-on without causing any inconvenience to the users?
I've read the documentation and configured addin manifest accordingly:
However, the users still are prompted to unblock the plugin manually in Add-in manager.
Kind Regards,
Jaromir
Andrii_Humeniuk
Hi @jzarczynski . Try adding the LoadBehavior parameter.
0 – loading immediately after loading Inventor (not recommended because it increases the loading time of Inventor itself);
1 – download after opening any document;
2 – loading after opening the assembly;
3 - download after opening the presentation;
4 - loading after opening the drawing;
10 – loading only on demand, via the Inventor API or manually using the add-on manager.
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
Andrii_Humeniuk
If the previous advice didn't help, then try adding this to your manifest: <LoadOnStartUp>1</LoadOnStartUp>
Frederick_Law
To remove "Block", the addin need to signed with signature.
Frederick_Law
