Make this rule so that if the user hits cancel it makes them start over?
bbrumfield
bbrumfield
I have rule to create a machine run time which did work well with one exception if your were to hit cancel on the inputbox you get an error :
Error in rule: Stock Sheet Metal Selection List - Test4, in document: CadTalk_Test_3.ipt
Conversion from string "" to type 'Double' is not valid.
I have tried multiple combinations with no success most ending in an endless loop.
The Value for machine run time can't be 0 or nothing
A positive value lets you move on,  and cancel can't let you skip to the next rule.
iProperties.Value("Custom", "Operation" & Space(1) & (oOperation) & Space(1) & "Run Time" & Space(1) & (oOperation)) = CObj(InputBox("Enter Machine Run Time" & Space(1) & "(Enter 0 if no value is available)", "Run Time", 0))
If iProperties.Value("Custom", "Operation" & Space(1) & (oOperation) & Space(1) & "Run Time" & Space(1) & (oOperation)) = 0 Or Nothing Then
	MessageBox.Show("ENTER RUN TIME VALUE", "A VALUE IN THIS FIELD IS REQUIRED", MessageBoxButtons.OK, MessageBoxIcon.Exclamation)
	GoTo MachineRunTime
End If
JelteDeJong
try it like this:
Dim newValue As String = String.Empty
While (String.IsNullOrEmpty(newValue))
    newValue = InputBox("Enter Machine Run Time" & Space(1) & "(Enter 0 if no value is available)", "Run Time", 0)
End While
iProperties.Value("Custom", "Operation" & Space(1) & (oOperation) & Space(1) & "Run Time" & Space(1) & (oOperation)) = newValue
Jelte de Jong
Blog: hjalte.nl - github.com
Curtis_Waguespack
Hi @bbrumfield,
Your input message states that the user can enter 0, but in your question you state that you do not want to allow a value of zero. If the later is true, then I might set the default to 1, and use something like this.
I hope this helps.
Curtis
Try
	oCurrentValue = iProperties.Value("Custom", "Operation" & Space(1) & _
Catch
	If oCurrentValue = "" Then oCurrentValue = 1
End Try
MachineRunTime :
oInput = CObj(InputBox("Enter Machine Run Time" & Space(1) _
	& "(Enter a value of 1 or more)", "Run Time", oCurrentValue))
If oInput = Nothing Then GoTo MachineRunTime
If oInput < 1 Then GoTo MachineRunTime
	(oOperation) & Space(1) & "Run Time" & Space(1) & (oOperation)) = oInput
bbrumfield
Hi Curtis,
Thank you! That rule solved the issue. The only thing I had to do was change 1 to 0.017, we log machine time in seconds. Interestingly the rule retains the current  value if run again.
Brent
