Code for saving iparts as dxf flat sheet
bionorica2015
bionorica2015
Hello
I have this code:
Sub CreateDxf()
Dim oDoc As PartDocument = ThisApplication.ActiveDocument
Dim oDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
Dim oPartMember As iPartMember
For Each oTab As iPartTableRow In oDef.iPartFactory.TableRows
MessageBox.Show(oTab.MemberName, "Name of the Member")
iPart.ChangeRow("", oTab.MemberName)
Dim oFeat As PartFeature
For Each oFeat In oDef.Features
If oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
If oDef.HasFlatPattern = False Then
oDef.Unfold
Else
oDef.FlatPattern.Edit
Dim odxf As String
Dim oPath As String
oPath = ThisDoc.Path & "\DXF"
If Not System.IO.Directory.Exists(oPath) Then
System.IO.Directory.CreateDirectory (oPath)
Dim odxfname As String
odxf = "FLAT PATTERN DXF?OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0&BendDownLayerLineType=37633&BendDownLayerColor=0;0;255&BendUpLayerLineType=37633&BendUpLayerColor=0;0;255IV_BEND;IV_BEND_DOWN;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES" _
+ "&RebaseGeometry=True" _
+ "&SimplifySplines=True" _
+ "&SplineTolerance=0.01" _
odxfname = oPath & "\" & oTab.MemberName & ".dxf"
oDef.DataIO.WriteDataToFile(odxf, odxfname)
oDef.FlatPattern.ExitEdit
MessageBox.Show ("DXF has been saved in this location: " + odxfname)
Else
MessageBox.Show ("There must be a sheetmetal component to get the dxf file!")
Next
Next
End Sub
But when I put it into vba to create macros these lines are getting red :
Please help what I must do to solve these problems?
PS: When I put it into ilogic rule these errors occur;
System.ArgumentException: Параметр задан неверно. (Исключение из HRESULT: 0x80070057 (E_INVALIDARG))
в System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
в Inventor.DataIO.WriteDataToFile(String Format, String FileName)
в ThisRule.Main()
в Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
в iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Yhis code is written for Inventor 2021. my Inventor is 2020
A.Acheson
The original ilogic rule works . There was some feature looping which is likely not being used  so I removed that. Are you running this rule in the factory file?
			oDef.Unfold
		Else
		Dim odxf As String
		Dim oPath As String
	Else
Next
 The VBA equivalent will take a lot of rework to remove System.IO reference and ilogic member change.
Regards
Alan
A.Acheson
For the VBA equivalent. Here is some reference information for the System Object to check if the folder exist in windows.  To make it easier I added the  reference to "Microsoft Scripting Runtime" under Tools>References. This article  shows how to do add this reference. Without this reference you will need to know the exact method rather than having full access to the list of methods available under the object.
Public Sub ExportiFactorytoDXF()
   Set oDoc = ThisApplication.ActiveDocument
   Set oDef = oDoc.ComponentDefinition
    'Read the folder in Windows
    '*********************Early bindings*****************
    'Add reference to "Microsoft Scripting Runtime" under tools>References (https://wellsr.com/vba/2018/excel/introduction-to-the-vba-filesystemobject/)
    'Early bindings allows access to the object collection
    Dim fs As FileSystemObject
    Set fs = New FileSystemObject
     '******************Late bindings*********
    'Dim fs As Object
    'Set fs = CreateObject("Scripting.FileSystemObject")
     'Create the folder path
     Dim oPath As String
     oPath = fs.GetParentFolderName(oDoc.FullFileName) & "\DXF"
    'check if the folder exist and if not create
    If fs.FolderExists(oPath) = False Then
        fs.CreateFolder (oPath)
    Dim oRow As iPartTableRow
    For Each oRow In oDef.iPartFactory.TableRows
    'Change the member
    oDef.iPartFactory.DefaultRow = oRow
   ' MsgBox(oRow.MemberName, "Name of the Member")
            oDef.Unfold
        Else
        Dim odxf, odxfname As String
        odxfname = oPath & "\" & oRow.MemberName & ".dxf"
        Call oDef.DataIO.WriteDataToFile(odxf, odxfname)
        MsgBox ("DXF has been saved in this location: " + odxfname)
    Else
        MsgBox ("There must be a sheetmetal component to get the dxf file!")
Next
End Sub
Regards
Alan
bionorica2015
Invalid argument in this line:
Tools-refernce-Microsoft Scriptig Runtime I put checked
A.Acheson
Maybe you need to set the DataIO object as per the API sample here.
Regards
Alan
