Cannot suppress the first element of the pattern
sevaslan
sevaslan
I'm trying to run a rule to suppress elements of a pattern. When I try to run the rule for Element1 it didn't work but it works for other elements. Any ideas?
			If [arka] = True Then
				Dim oDoc As AssemblyDocument
				oDoc = ThisApplication.ActiveDocument
				Dim oPattern As OccurrencePattern
				oPattern = oDoc.ComponentDefinition.OccurrencePatterns.Item("Component Pattern 10:1")
				Dim oElement As OccurrencePatternElement
				oPattern.OccurrencePatternElements.Item(1).Suppressed=False
          Else
				oPattern.OccurrencePatternElements.Item(1).Suppressed = True
Michael.Navara
This is how Inventor works. Suppress the first element in pattern is not possible in both ways (UI/API)
sevaslan
If i need to deactivate the first element what else can i do? Is there any other way?
Michael.Navara
For example you need to redefine pattern and start from second position. Or you can place components to its right position one by one (without pattern)
