Loop through all sheets
I have adapted code I found for changing the layer of sketch geometry, within a sketch created in a drawing view. But I can't manage to adapt it to loop through all sheets. Below is the code that works for the active sheet only.
How do I get this code to loop through all sheets winthin the .idw?
Thanks for your help
M
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
oActiveSheet = oDrawDoc.ActiveSheet
' Create a Drawing View Object
Dim oDrawingView As DrawingView
Dim oDrawingSketch As DrawingSketch
Dim oSketchEntity As SketchEntity
Dim oLayer As Layer
oLayer = oDrawDoc.StylesManager.Layers.Item("test")
For Each oDrawingView In oActiveSheet.DrawingViews
   For Each oDrawingSketch In oDrawingView.Sketches
           If oDrawingSketch.Name = "Workpiece Size" Then
               oDrawingSketch.Edit
               For Each oSketchEntity In oDrawingSketch.SketchEntities
                   oSketchEntity.Layer = oLayer
               Next
               oDrawingSketch.ExitEdit
   Next
Next
iLogicVb.UpdateWhenDone = True
MechMachineMan
Sub Main()
    oDrawDoc = ThisApplication.ActiveDocument
    For Each oSheet in oDrawDoc.Sheets
        ProcessSheet(oSheet)
    Next
    oDrawDoc.Update
End Sub
Dim oLayer As Layer
Sub ProcessSheet(oSheet As Sheet)
    For Each oDrawingView In oSheet.DrawingViews
               oDrawingSketch.Edit
               Next
       Next
    Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Thanks, this works (sorry for the late reply). This code is perfect. I now need to work out how to replace the line "oLayer = oDrawDoc.StylesManager.Layers.Item("test")" with a layer name that is set per sheet from a promted entry that exists on each sheet. I have adapted code that I have found on cadlinecommunity. This loops through all sheets and creates a layer per sheet based on the promted entry.
Is it possible to replace "oLayer = oDrawDoc.StylesManager.Layers.Item("test")" with the new layer???
Thanks in advance for any help you can give me
M
On Error Resume Next
Dim oSheet As Sheet
Dim oPromptEntry
i = 1
For Each oSheet In oDrawDoc.Sheets
i = i+1
ThisApplication.ActiveDocument.Sheets.Item(i).Activate
       oTitleBlock=oSheet.TitleBlock
   oTextBoxes=oTitleBlock.Definition.Sketch.TextBoxes
   For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
   Select oTextBox.Text
       Case "{Item.Thickness}"
           oPromptEntry = oTitleBlock.GetResultText(oTextBox)
                       Dim oNEWlayer As Layer
                       oNEWlayer = oDrawDoc.StylesManager.Layers.Item("Workpiece Size").Copy("XLYP1H" & oPromptEntry)
   End Select
   Next
Next
