Lookup/snoop tool
Lookup/snoop tool
Lookup/snoop tool
Hi there,
I'm a revit developper and I'm fairly new to the inventor programming business. What I am really missing is a tool which I wonder if it is available for inventor. In Revit there is a tool called Revit lookup (or Revit Snoop), which gives a developper all kinds of usefull information. You can get information about the openend document, the active database and the selected element.
http://thebuildingcoder.typepad.com/blog/2014/04/revitlookup-for-revit-2015.html
Is such a tool available for inventor?
And if not, can somebody make it real fast please 🙂
I can't imaging there isn't because I can't do without it in Revit API.
Curtis_Waguespack
HI R.van.den.Bor,
I looked at the link and could not determine what that tool does (I don't use Revit).
Can you provide a description of what it is / what it does / how it works?
I hope this helps.
Curtis
It's like I wrote "You can get information about the openend document, the active database and the selected element."
So for instance, when I click on a family (part), I get all kind of information about this family (what parameters it has and where the are stored, what elementid it has ect.)
adam.nagy
Autodesk Support
Autodesk Support
Hi Remy,
In case of Inventor you can simply use the VBA environment to snoop around in the database:
http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
Cheers,
Adam Nagy
Autodesk Platform Services
