iLogic help
iLogic help
esmall1894
iLogic help
esmall1894
Ok i give!
I know this really simple but i cant seem to get it to work.
I have a simple plate with four or eight holes.  Two different hole patterns one of which is named "eight bolt"
I have User Parameter "eight_hole" as a True/False.
All i want to do is suppress the "eight bolt" feature when the user parameter "eight_hole" goes to false.  Simple right?
I have set all trigger conditions to this iLogic code but still doesn't work.  What is up with this?
SyntaxEditor Code Snippet
If Parameter("eight_hole") = True Then
Feature.IsActive("eight bolt") = True
Else
Feature.IsActive("eight bolt") = False
E. Small
Eric Small
Autodesk Inventor Professional
Sr. Mechanical Designer
Curtis_Waguespack
Hi esmall1894,
Change the way you call the parameter from Parameter("eight_hole") to eight_hole and then it will automatically update.
Or you can edit the Form and add an Apply button (rather than just the Done button).
I hope this helps.
Curtis
If eight_hole = True Then
Else
esmall1894
I changed the parameter as suggested to eight_hole. insted of "eight_hole"  and I get the erro message below.  Any thoughts?
Error in rule: Suppress 8 Hole, in document: Beam Bolt Plate.ipt
Parameter: Could not find a parameter named: "True"
If Parameter(eight_hole) = True Then
Else
Eric Small
Curtis_Waguespack
Else
Hi esmall1894,
Have a look at my post again. You need to remove the word Parameter as well as the parenthesis, so it just says eight_hole in blue.
I hope this helps.
Curtis
Else
esmall1894
I get now.  Than worked thanks for the help
Eric Small
danny.lewisA9QBW
@Curtis_Waguespack
I've got an issue where the multi-value drop downs are one of the things that are being generated by the ilogic codes, so I won't have the specific parameter to put in the code (eg. eight_hole), until after the code has run the first time.
Long story short, is there any other way to force iLogic to trigger on a change of multi-value drop down?
