Error in Ilogic rule
hope anyone can help me.
I am using iLogic to change the LOD from Main to iLogic everytime when i open the assembly.
The rule has been working without any error for 2 years till now.
Now i got the message that this rule got an error when i try to checkin this assembly.
But when i run this rule in the assembly there is no error message.
Here is the rule:
SyntaxEditor Code Snippet
Dim doc as AssemblyDocument = ThisDoc.Document
If doc.ComponentDefinition.RepresentationsManager.ActiveLevelOfDetailRepresentation.LevelOfDetail <> 56072 Then 'LevelOfDetailEnum.kMasterLevelOfDetail
Dim oLOD As LevelOfDetailRepresentation
Dim oAsmCompDef As ComponentDefinition
oAsmCompDef = doc.ComponentDefinition
oLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("iLogic")
oLOD.Activate(True)
I tried another one:
Try
oLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("iLogic").Activate(True)
Catch
Dim nLOD As LevelOfDetailRepresentation
nLOD = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("iLogic")
oLOD = nLOD
Finally
End Try
But i got the same result.
Anyone got an idea what´s the problem now?
Thanks in advance.
Owner2229
The first one works just fine for me. Just make sure that the LOD named "iLogic" exists in your assembly.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Hi Mike,
the LOD is existing.
As i said, i am using this assembly for 2 years without any problems.
But now, i don´t know why, i got this error and i didn´t change anything.
Owner2229
Can you share the assembly file (no need to attach the nested part files) and the error it's throwing?
Mike
