Looking for ilogic code that will map a specific material and color to ALL part files within an assembly?
chris
Advisor Advisor
Message 1 of 9
chris
Just wondering if anyone has a iLogic snippet that they don't mind sharing that would replace the material and color of ALL parts within an assembly with a predefined material and color.
I have several large assemblies that the "boss" need to have shown as a specific material with a specific color and instead of spending the next 3 weeks single selecting individual parts I was wondering if this could be done in iLogic?
Replies (8)
Message 2 of 9
earl_cody
Here's a start. If you're looking for appearance/color override from the material, that can be done with a few more lines. Also assuming the assembly BOM is flat, but more code can be added to handle subassemblies.
iLogicVb.UpdateWhenDone = True
'get material library
Dim libMaterial As Inventor.AssetLibrary = ThisApplication.AssetLibraries.Item("Autodesk Material Library")
'specify material
Dim material As Inventor.MaterialAsset = libMaterial.MaterialAssets.Item("Glass")
'get active assembly document
Dim asmDoc As Inventor.AssemblyDocument = ThisApplication.ActiveDocument
'get assembly's definition
Dim asmDef As Inventor.AssemblyComponentDefinition = asmDoc.ComponentDefinition
'clear any appearance overrides that may be set at the assembly level
Call asmDef.ClearAppearanceOverrides()
'get handle for all part occurrences in the assembly
Dim asmOccurences As Inventor.ComponentOccurrences = asmDef.Occurrences
'for each occurance in the assembly document
For Each occ As Inventor.ComponentOccurrence In asmOccurences
    '** if user has subassemblies, then recursive method to handle those will be needed
    'but keeping it short/straightforward for now
    'if the occurance is of type part document
    'could also add handling for sheetmetal if needed
    If (occ.Definition.Type = Inventor.ObjectTypeEnum.kPartComponentDefinitionObject) Then
        'get handle for the part document
        Dim partDoc As Inventor.PartDocument = occ.Definition.Document
       'if the material isn't already set to the specified material, then change the material
        If (partDoc.ActiveMaterial.DisplayName <> material.DisplayName) Then
            'set the material of the part document
            partDoc.ActiveMaterial = material
        End If
    End If
Next
'update the assembly document to propagate sublevel changes
Call asmDoc.Update()
'simple message box to let user know that script has finished
MessageBox.Show("Done")
Message 3 of 9
chris
@earl_cody this worked great!!
is it much work to adjust it to work with sub assemblies?
Message 4 of 9
A.Acheson
Edit:
Just one change I think to change "asmDef.Occurrences" to "asmDef.Occurrences.AllLeafOccurrences"
This will work with the parts in each assembly.
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=GUID-86E425C0-69CD-4004-A6F6-ECB2878B499F
And here is a more digestible article to navigate assemblies.
Regards
Alan
Message 5 of 9
earl_cody
@A.Acheson - Thank you for the suggestion!
@chris - Nice! This should work for the nested parts now.
'specify material
'get handle for all occurrences in the assembly
'for each leaf occurrence in the assembly document
For Each occ As Inventor.ComponentOccurrence In asmOccurences.AllLeafOccurrences
        End If
    End If
Next
Message 6 of 9
chris
@earl_cody (sorry for the reply), but for some reason I am getting an error on line 37? It was working fine yesterday but it's not working today?
Message 7 of 9
A.Acheson
Edit: In further testing copying doesn't seem to be necessary.
I would think your material asset is not existing locally in the part document.This is why your getting a string error trying to find its name. Use these lines to check the material locally if it exists then move to set it and if it doesnt then the catch comes into play and copies from material library. See sample setting appearance much the same as setting material asset.
'specify material
Dim LibMatAsset As MaterialAsset = libMaterial.MaterialAssets.Item("Glass")
' Copy the asset locally.
Try
   Dim LocalMatAsset As MaterialAsset
LocalMatAsset = partDoc.Assets.Item("Glass")
Catch
LocalMatAsset = LibMatAsset.CopyTo(partDoc)
End Try
If (partDoc.ActiveMaterial.DisplayName <> LocalMatAsset.DisplayName) Then
partDoc.ActiveMaterial = LocalMatAsset
End If
Regards
Alan
Message 8 of 9
J-Camper
@chris,
Just an FYI, you can window select all occurrences in an assembly and change the material and appearance from the dropdown lists without any iLogic:
Message 9 of 9
A.Acheson
If you have content center parts/parts that are read only then you might get an error like this.
Change this line to ensure document is modifiable.
 If (partDoc.ActiveMaterial.DisplayName <> material.DisplayName) AndAlso partDoc.IsModifiable Then
If that still fails you will need to place in a logger line like so and you can see what document it is stopping on.
Logger.Info("Document DisplayName: " & partDoc.DisplayName)
Regards
Alan
