Hi Jhoel, I was reading your post on the Autodesk iLogic: Export All Flat Patterns to One DXF - Customization
ligwin
ligwin
Hello all!
this is my first time posting on here and I’m hoping to get some quick help here.
I found this article below for an iLogic rule to automate the export of multiple flat patterns from a sheet metal part assembly into one .dxf file written by @JhoelForshav
https://clintbrown.co.uk/2020/09/05/ilogic-export-all-flat-patterns-to-one-dxf/
However, I have specific colors that I need the bend lines, interior cut lines, and exterior cut lines to export as in the .dxf file. Any advice on how to achieve this?
I will be planning to create templates of various sheet metal assemblies to work from for reoccurring work and would like to automate the process as much as possible.
I am terrible at coding and have never written and iLogic command before so any and all help is appreciated to edit the code in the attached link to do what I need.
nedeljko.sovljanski
Hi @ligwin
That code i quite good and could be useful in you case but you have to add some additional lines for exporting colors.
Use this documentation about options (varable oOptions in code)
https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=DataIO
and analize sample code (https://help.autodesk.com/view/INVNTOR/2022/ENU/?guid=WriteFlatPatternAsDXF_Sample)
