LOD of subassemblies
Message 1 of 12
Anyone please help.
I have an assembly that contains multiple subassemblise where I want to set or create a LOD.
I have a problem og getting the sub-assemblies to change as I somehow only get the top-level assembly to act to the following code.
The following code is written in the iLogic editor:
Start:
Dim asmDoc As AssemblyDocument
asmDoc = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = asmDoc.ComponentDefinition
Dim oLODRep As LevelOfDetailRepresentation
Dim doc As Document
For Each doc In asmDoc.AllReferencedDocuments
' Check for assembly documents.
If doc.DocumentType = kAssemblyDocumentObject Then
    Try
        'Activate a writeable LOD (master LOD is not writeable)
      AsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Test").activate
        Catch
        'Assume error means this LOD does not exist, so create it (will be deleted at end)
        oLODRep = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("Test")
    End Try
End If
Next
End
Can anyone point me in the right direction of getting the sub assemblies to act on the code above?
Thanks in advance
Kari
Replies (11)
Message 2 of 12
Vladimir.Ananyev
Use ComponentOccurrence.SetLevelOfDetailRepresentation method to switch components to the desired LOD.
At the top level of assembly tree you may consider something like this :
For Each oOcc As ComponentOccurrence In oMainAssyDef.Occurrences
  If oOcc.Suppressed Then Continue For
  Try
    If oOcc.DefinitionDocumentType _
         = DocumentTypeEnum.kAssemblyDocumentObject Then
      oOcc.SetLevelOfDetailRepresentation(TargetLODName)
    End If
  Catch
  End Try
Next
To do the same work in multi-level main assembly you may consider the following workflow.
1.  AllReferencedDocuments property of the top assembly document  gives you access to all referenced subassembly documents.
2. For every found subassembly  you may find  all occurrences that reference this subassembly document at all levels in the main assembly.  Use ComponentOccurrences.AllReferencedOccurrences property for this purpose.
3. Then you may call ComponentOccurrence.SetLevelOfDetailRepresentation method to set desired LOD in every subassembly occurrence.
Alternative workflow:  you may recursively traverse an assembly and set desired LOD in every subassembly occurrence.
See “Traverse an Assembly API Sample” in the Inventor API Help.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 3 of 12
Thanks for your promt reply.
It works perfectly. At this time I will settle for the first level assemblies as multi-level main assembly is "over my head" at the moment.
Message 4 of 12
One additional quick question: If the "TargetLODName" does not excist I want to create it in the Catch part...
How can I acces the Component definition for each Occurrence an add the LOD if it does not excist?
Message 5 of 12
Vladimir.Ananyev
1. You could get ComponentDefinition object.from ComponentOccurrence.Definition property.
2. To create new LOD use RepresentationsManager:
' Create a new level of detail representation.
' The new representation is automatically activated.
Set oLODRep = oAsmCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add("Part2Suppressed")
Look at the “Create a level of detail representation API Sample” in the Inventor API Help.
Cheers,
Vladimir Ananyev
Message 6 of 12
I cannot figure it out... I works fine for the top-level assembly according to the API-samples You are reffering to, but when it comes to the occurrences in the assembly I fail.
Dim oMainAssyDef As AssemblyComponentDefinition
oMainAssyDef = ThisApplication.ActiveDocument.ComponentDefinition
Try
    oMainAssyDef.RepresentationsManager.LevelOfDetailRepresentations.Item("Test").activate
    Catch
    oLODRep = oMainAssyDef.RepresentationsManager.LevelOfDetailRepresentations.Add("Test")
End Try
'Iterate through all of the referenced documents at
'all levels of the assembly.
'If the Occurent is suppressed then leav it as such
Try
      oOcc.SetLevelOfDetailRepresentation("Test")
    End If
  Catch
    'THIS IS WHERE I FAIL...
  End Try
Next
I have looked through the API samples but I cannot figure out how to access the ComponentOccurrence.Definition for each individual occurrence in the iteration. Please assist me some more.
Message 7 of 12
Vladimir.Ananyev
Could you look at this thread:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Change-LOD-in-component/m-p/3452094/hi...
Vladimir Ananyev
Message 8 of 12
Perfect!
With:
"If oOcc.Suppressed Then Continue For"
And some other small addtioins/adjustments... This will fit fine for an external rule.
Thanks!
Message 9 of 12
I have taken the task to traverse through the assembly.
It works fine, but, when I traverse the assembly structure I cannot maintain the LOD that I set throughout the structure as it changes when the code reaches the next level, see attached code and picture.
The assembly that I tested on consists of:
  • Top level assembly
  • Two sub assemblies where one of the sub assemblies contains multiple level of subassemblies
The code does the following: (The numbering relates to the pictures in the attached file)
  1. Looks at the top level assembly LOD
  2. See if the first subassembly contains this LOD; if yes set it as active, if not create it and set it as active
  3. See if the next subassembly contains this LOD; if yes set it as active, if not create it and set it as active
  4. As the next subassembly contains multiple subassemblies the code traverses through the assembly structure... But here the code failes
  5. The code goes to the next level again but with the same result...
How can I maintain the LOD of all the assemblies and subassemblies?
Or should I try another approach?
Any input would be helpful.
CODE start
PrivateSub Button5_Click(sender As System.Object, e As System.EventArgs) Handles Button5.Click
        ' Get the active assembly.
        Dim oAsmDoc AsAssemblyDocument
        oAsmDoc = _invApp.ActiveDocument 'ThisApplication.ActiveDocument
        'Debug.Print(oAsmDoc.DisplayName)
        Dim oAsmDocDef AsAssemblyComponentDefinition
        oAsmDocDef = oAsmDoc.ComponentDefinition
        Dim ActiveLODRepName AsString
        Try
            ActiveLODRepName = oAsmDocDef.RepresentationsManager.ActiveLevelOfDetailRepresentation.Name
        Catch ex1 AsException
            ActiveLODRepName = "Test"
        EndTry
        ' Call the function that does the recursion.
        Call TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1, ActiveLODRepName)
    EndSub
    PrivateSub TraverseAssembly(Occurrences AsComponentOccurrences, _
    Level AsInteger, ActiveLODRepName AsString)
        ' Iterate through all of the occurrence in this collection. This
        ' represents the occurrences at the top level of an assembly.
        Dim oOcc AsComponentOccurrence
        Dim oCompDef AsAssemblyComponentDefinition
        ForEach oOcc In Occurrences
            ' Check to see if this occurrence represents a subassembly
            ' and recursively call this function to traverse through it.
            If oOcc.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
                If oOcc.Suppressed ThenContinue For
                Try
                    oOcc.SetLevelOfDetailRepresentation(ActiveLODRepName)
                Catch
                    oCompDef = oOcc.Definition
                    oCompDef.RepresentationsManager.LevelOfDetailRepresentations.Add(ActiveLODRepName)
                EndTry
                Call TraverseAssembly(oOcc.SubOccurrences, Level + 1, ActiveLODRepName)
            EndIf
        Next
    EndSub
CODE end
Message 10 of 12
Any idea?
Feel free...
Message 11 of 12
Vladimir.Ananyev
I prefer two-step workflow.
Step 1
We can obtain the list of all subassembly documents filtering TopAssemblyDoc.AllReferencedDocuments collection.  In every found assembly document we may (if required) set up all desired LODs (+ update & save)
Step 2
For every custom LOD in the top assembly:
Activate this LOD in the top assembly and then traverse top assembly tree to activate this LOD in subassemblies using SetLevelOfDetailRepresentation(LODname) method.
Vladimir Ananyev
Message 12 of 12
christian.brower
I just came across this same issue. Did you ever find a solution?
