Caterpillar weld problems
hi,
I have a Caterpillar weld added to an assembly in one of the views. My code (on .net) makes changes to the model and updates it to the drawing file. Also a .dwg file is generated. This process works fine on the PC where i develop the application, but when i try this out on a different PC, these weld symbols are not being reproduced. On opening the Inventor Drawing files on this new PC, the weld symbols are still missing, but if i open the view where i have added the weld and make a minor change and revert back ( say change master to default and back) and click OK, the weld symbols reappear!
I tried using an activeview.update(), but nothing changed.
In case it helps: When i run the application on the 2nd PC, i just have a copy of the Model files and the Inventor drawing files which are called by the VB.NET application, thats installed to the new PC.
Any way to overcome this?
umm.. any related help please?
I found a workaround to this. Since it looked like the view needed a sort of a 'refresh', i made a modification to the code to enable something in the view.. for eg ThreadedFeatures, and do a save2.
Private Sub modifyView(ByVal invDoc As DrawingDocument)
        Dim view_1 As DrawingView
        Dim sheet_1 As Sheet
        sheet_1 = invDoc.Sheets(1)
        For Each view_1 In sheet_1.DrawingViews
            If view_1.DisplayThreadFeatures = True Then
                view_1.DisplayThreadFeatures = False
            ElseIf view_1.DisplayThreadFeatures = False Then
            invDoc.Save2()
        Next
    End Sub
 Poor coding practice.. but it works  😛
