Loading an Icon in Inventor 2025
pfk
pfk
Hi
My Inventor 2024 addin uses the following to put a button with an icon on the toolbar.
            stdole.IPictureDisp standardIconIPictureDisp = null;
            stdole.IPictureDisp largeIconIPictureDisp = null;
            if (standardIcon != null)
#pragma warning disable CS0618 // Type or member is obsolete
                standardIconIPictureDisp = Support.IconToIPicture(standardIcon) as stdole.IPictureDisp;
                largeIconIPictureDisp = (stdole.IPictureDisp)Support.IconToIPicture(largeIcon);
#pragma warning restore CS0618 // Type or member is obsolete
            mButtonDef = AddinGlobal.InventorApp.CommandManager.ControlDefinitions.AddButtonDefinition(
                displayName, internalName, commandType,
                clientId, description, tooltip,
                standardIconIPictureDisp, largeIconIPictureDisp, buttonDisplayType);
However this does not work with Inventor 2025 as .NET no longer supports Microsoft.VisualBasic.Compatibility.VB6 which provides the Support.IconToIPicture function.
Paul
WCrihfield
Hi @pfk.  I do not currently create Inventor add-ins, or code with C#, but I may be able to help with this specific issue.  There has been a newer way to convert between the 'IPictureDisp' type and the 'Image' type for further processing/conversion.  It uses the System.Windows.Forms.AxHost Class, or at least a sub class that utilizes that class.  Below are a few links you can look into.  The first is the oldest.
https://modthemachine.typepad.com/my_weblog/2012/05/thumbnail-viewer-component-on-a-64-bit-system.ht...
https://forums.autodesk.com/t5/inventor-programming-ilogic/ilogicmini-toolbar-combo-box-list-item-ic...
https://learn.microsoft.com/en-us/dotnet/api/system.windows.forms.axhost
https://learn.microsoft.com/en-us/dotnet/api/system.windows.forms.axhost.getipicturedispfrompicture
https://learn.microsoft.com/en-us/dotnet/api/system.windows.forms.axhost.getpicturefromipicturedisp
https://learn.microsoft.com/en-us/dotnet/api/system.drawing.image
https://learn.microsoft.com/en-us/dotnet/api/system.drawing.image.save
https://learn.microsoft.com/en-us/dotnet/api/system.drawing.image.getthumbnailimage
Wesley Crihfield
(Not an Autodesk Employee)
Michael.Navara
See the Inventor 2025 SDK. There is a sample how to convert Icon to IPictureDisp
...\DeveloperTools\Samples\VCSharp.NET\AddIns\SimpleAddIn\PictureDispConverter.cs
JelteDeJong
There is an alternative to the "Microsoft.VisualBasic.Compatibility.VB6 ". You can create your own utility class that lets you get rid of that namespace functionality.
You can find the code for the utility class here:
https://adndevblog.typepad.com/manufacturing/2012/06/how-to-convert-iconbitmap-to-ipicturedisp-witho...
In my tutorial post "Adding icons to your buttons" you can see how to use the utility class. However, it's written in vb.net
Jelte de Jong
Blog: hjalte.nl - github.com
pfk
...\DeveloperTools\Samples\VCSharp.NET\AddIns\SimpleAddIn\PictureDispConverter.cs worked nicely - thank you.
Paul
gilsdorf_e
Honestly, it seems very cumbersome just to have icons loaded in Inventor addons. And it did not get better with .NET 8.0. Is this something that could be tackled by the Autodesk developers in the Inventor API?
