Message 1 of 8
I'm working on some code to update some older files which may or may not contain an event trigger. What I'm trying to come up with is an ilogic that I can have it clear out any event triggers that are existing and add the new one in if it doesn't exist. This would be added to my existing code so that this would run before the save. The current code will add the event correctly but once I save again it leaves a rule in the event but has no name to it and errors out.
Sub Main()
RemoveRulesfromEventTrigger
AssemblyEvents
End Sub
Function GetiLogicEventPropSet(cDocument As Document) As Inventor.PropertySet
On Error Resume Next
iLogicEventPropSet = cDocument.PropertySets.Item("iLogicEventsRules")
If iLogicEventPropSet Is Nothing Then
iLogicEventPropSet = cDocument.PropertySets.Item("_iLogicEventsRules")
If iLogicEventPropSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
Call iLogicEventPropSet.Delete
iLogicEventPropSet = cDocument.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
MsgBox("Unable to create the Event Triggers property for this file!", , "Event Triggers Not Set")
Err.Raise(1)
Exit Function
On Error GoTo 0
Return iLogicEventPropSet
End Function
Sub RemoveRulesfromEventTrigger()
Try
Dim EventTrigger = ThisDoc.Document.PropertySets.Item("{2C540830-0723-455E-A8E2-891722EB4C3E}")
'MsgBox(x.Count)
If EventTrigger.Name = "StockNumber-Assembly_Copy" Then
Return
Else
ThisDoc.Document.PropertySets.Item("{2C540830-0723-455E-A8E2-891722EB4C3E}").Delete
Catch
End Try
End Sub
Sub AssemblyEvents
Dim EventPropSet As Inventor.PropertySet
EventPropSet = GetiLogicEventPropSet(ThisApplication.ActiveDocument)
' To make sure that the document has an iLogic DocumentInterest, add a temporary rule
'EventPropSet.Add("file://Accessory List", "AfterDrawingViewsUpdate", 1801)
EventPropSet.Add("file://StockNumber-Assembly_Copy", "BeforeDocSave", 700)
'After Open Document : AfterDocOpen : 400
'Close(Document) : DocClose : 500
'Before Save Document : BeforeDocSave : 700
'After Save Document : AfterDocSave : 800
'Any Model Parameter Change : AfterAnyParamChange : 1000
'Part Geometry Change** : PartBodyChanged : 1200
'Material Change** : AfterMaterialChange : 1400
'Drawing View Change*** : AfterDrawingViewsUpdate : 1500
'iProperty(Change) : AfterAnyiPropertyChange : 1600
'Feature Suppression Change** : AfterFeatureSuppressionChange : 2000
'Component Suppression Change* : AfterComponentSuppressionChange : 2200
'iPart / iAssembly Change Component* : AfterComponentReplace : 2400
'New Document : AfterDocNew : 2600
InventorVb.DocumentUpdate()
End Sub
