Need Help with a Setup Sheet Post
b_krznaric
b_krznaric
I have a mill and lathe setup sheet separately. The Mill setup sheet still works, but my lathe post will not work, I have tried for weeks, if I use the mill sheet with a lathe job it works but obviously not the information I want. I keep getting an error I will post it below. Any help would be GREATLY appreciated! I didnt add the stuff at the top of the error page because it doesnt seem important. Some extra info-I havent used this post in about a year, and not on this specific computer. I do have the setup sheet and excel file in the same folder, the name is correct in the post configuration as well.
I thought about just copying all the information from the lath setup sheet and adding it onto my mill sheet but I dont know how to bring along all the information attached to each cell. Thanks Everyone!
(If anyone has a good setup sheet post and excel file I would love to try it out as well!)
Error: worksheet.mergeCells is undefined
Error at line: 874 (lathe setup sheet.cps)
Failed while processing onCommand() for record 3794.
Error: Failed to invoke function 'onClose'.
Error: Failed to invoke 'onClose' in the post configuration.
Error: Failed to execute configuration.
Stop time: Saturday, August 2, 2025 3:45:26 PM
Post processing failed.
C_Haines_ENG
The MergeCells property tells if a cell is merged, which I would be surprised if you were actually using. It also doesn't apply to the worksheet, but a range within a worksheet. Try fixing this line to not run into the error.
b_krznaric
Im not sure how to fix the line, also there may be a problem with the line but it worked for years with no issues. Let me know how you think I could fix it if possible. Thanks for the reply!
