List sketch symbols in a folder
Hello all,
I'm trying to copy a folder and symbol
from a drawing template to another drawing.
I need to read the list of folders and for each folder the list of sketch symbols.
Thanks for any info.
Best Regards
Massimo
MechMachineMan
Are you even trying?
In your last post, I directed to you to a link for a thread that has a solution for this.
All you had to do was extract a simple snippet from it, and then extrapolate to create a recursive function to go through the folders as well.
Again, the post: https://forums.autodesk.com/t5/inventor-customization/copy-sketched-symbols-with-folders/td-p/713142...
The snippet:
Sub List Symbols()
	Dim oPane As BrowserPane
	Dim oNode As BrowserNode
	Dim oTopNode As BrowserNode
	Dim oDwgResourcesFolder As BrowserNode
	Dim oSketchedSymbolsFolder As BrowserNode
	oPane = ThisApplication.ActiveDocument.BrowserPanes("Model")
	oDwgResourcesFolder = oPane.TopNode.BrowserNodes.Item("Drawing Resources")
	oSketchedSymbolsFolder = oDwgResourcesFolder.BrowserNodes.Item(4)
	For Each oNode In oSketchedSymbolsFolder.BrowserNodes
		oNodeName = Right(oNode.FullPath, Len(oNode.FullPath) - InStrRev(oNode.FullPath, ":", -1))
	Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Hi Justin,
no excuses, I did not tried,
and thanks for your help.
Thanks again for the support.
Regards
Massimo
