Linking iFeature properties to multi value text parameters.
Hi there,
Does anybody know of a way to link each iFeature with a multi value text parameter or vice versa in order to populate a hole table with the desired description?
Baiscally I have drillings called say, Drilling-A through to D if they all appeared in a part file and the drawing needs to contain a hole table describing each, how can I link the values of a multi value text parameter with the browser names of the drillings so they do not need to be picked and will update automatically should they be altered in the model?
I know that by using the multi value text parameter and picking the centre mark on the drawing I can call out the features in the hole table and assign the text in the table from the user parameters but there is no real link between the two.
Hopefully this makes sense and somebody is able to help.
Anybody please?
marcin_otręba
could you attach that ifeature ?
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
