accessing hidden partlistrows
hi
is there a way to access a hidden partlistrow or the visible partlist row??
rjay75
Check the visible property on a PartsListRow to see if it is Hidden or visible.
how can i check it?
i can hide some of the rows of the partlist programmatically.
my problem is what is the code to access the visible/hidden rows in the partlist programmatically.
rjay75
There's no difference in access to hidden or visible rows. Here's some code that cycles through all the rows and counts the hidden and visible rows.
Dim hiddenRowCnt As Long
Dim visibleRowCnt As Long
Dim dwgDoc As DrawingDocument
Dim prtList As PartsList
dwgDoc = ThisDoc.Document
If dwgDoc.ActiveSheet.PartsLists.Count > 0 Then
	prtList = dwgDoc.ActiveSheet.PartsLists.Item(1)
	Dim prtListRow As PartsListRow
	For Each prtListRow In prtList.PartsListRows
		If prtListRow.Visible Then
			visibleRowCnt = visibleRowCnt + 1
		Else
			hiddenRowCnt = hiddenRowCnt + 1
	Next
	MessageBox.Show(String.Format("Rows:" + vbCrLf + "Hidden: {0}" + vbCrLf + "Visible: {1}", hiddenRowCnt, visibleRowCnt))
 All the rows are in on collection called PartsListRows. Hidden and visible. Visible Property gets or sets whether the row is hidden or visible.
So in this example the prtListRow.Visible will be true or false for visible if true or hidden if false.
