Length of extrusion or sweep
donaldleigh
donaldleigh
Evening all
I have 2 rules, one returns the length of the 1st feature if its an extrude "Length Extrude" and the other returns the length of a sweep, the browser name must be called "Sweep1", This rule is called "Length Sweep". Both these rules work well.
What I an trying to do is to have another rule like below.
If (1st feature if its an extrude) Then
       Run rule "Length Extrude"
Else if 1st feature is a sweep and called "Sweep1" Then
      Run Rule "Length Sweep"
Else
End If
Any help would be great
matt_jlt
Try this
' Check document is a part / a document is open
If ThisApplication.Documents.VisibleDocuments.Count = 0 Or ThisApplication.ActiveEditDocument.DocumentType <> Inventor.DocumentTypeEnum.kPartDocumentObject Then
	MessageBox.Show("A part document must be open")
End If
' Get active part document
Dim oDoc As Inventor.PartDocument = ThisApplication.ActiveDocument
' Get part component definition
Dim oCompDef As Inventor.PartComponentDefinition = oDoc.ComponentDefinition
' Check there are features before accessing them
If oCompDef.Features.Count = 0 Then
	MessageBox.Show("There are no features in this part")
End If
' Check the first feature type
Select Case oCompDef.Features(1).Type ' Collection is not zero based so use 1 to get the first item
	Case Inventor.ObjectTypeEnum.kExtrudeFeatureObject
		MessageBox.Show("Extrude Feature")
		' Run extrude rule
		'iLogicVb.RunRule("ruleName")
	Case Inventor.ObjectTypeEnum.kSweepFeatureObject
		MessageBox.Show("Sweep Feature")
		' Run sweep rile
End Select
donaldleigh
Hi @matt_jlt
Thanks for the reply
Just had a quick look and it looks great. Will have more of a test next week.
Cheers
donaldleigh
Hi @matt_jlt
The code you provided works great but, (now the fun part to explain). When this rule is fired in a part that is not opened, as only an assembly will be open, I have an error. How do I change the start of this code so its run at the part level from an assembly. This code is also set up as an external rule.
iLogicVb.UpdateWhenDone = True
End If
'oDoc = ThisApplication.ActiveDocument
End If
If oCompDef.Features(1).Type = Inventor.ObjectTypeEnum.kSweepFeatureObject Then
	iLogicVb.RunExternalRule("Length Sweep")
Else
	iLogicVb.RunExternalRule("Length - Rev 1")
End If
Return
		'MessageBox.Show("Extrude Feature")
		'Run extrude rule
		'MessageBox.Show("Sweep Feature")
		'Run sweep rile
End Select
donaldleigh
@matt_jlt
Got it to work now. Thanks anyway
