Copy Prompted Entries to Drawing custom iproperties
johan.degreef
Advisor Advisor
johan.degreef
I want each timle the titleblock is updated, to copy the prompted entries from the tilteblockto the drawing custom iproperties. I have have found this code and modified it to my naming scheme, but they don't get copied. Can anyone point me in the right direction?
On Error Resume Next
'https://www.cadlinecommunity.co.uk/hc/en-us/articles/203292761
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oPromptEntry
Dim oCurrentSheet
oCurrentSheet = oDoc.ActiveSheet.Name
i = 1
For Each oSheet In oDoc.Sheets
  'i = i+1
  ThisApplication.ActiveDocument.Sheets.Item(i).Activate
       oTitleBlock=oSheet.TitleBlock
    oTextBoxes=oTitleBlock.Definition.Sketch.TextBoxes
    For Each oTextBox In oTitleBlock.Definition.Sketch.TextBoxes
    Select oTextBox.Text
        Case "PTN_DRAWING"
            oPromptEntry  =  oTitleBlock.GetResultText(oTextBox)
            iProperties.Value("Custom", "PTN_DRAWING")=oPromptEntry
        Case "PTN_REVISION"
            iProperties.Value("Custom", "PTN_REVISION")=oPromptEntry
        Case "PTN_TITLE_EN"
            iProperties.Value("Custom", "PTN_TITLE_EN")=oPromptEntry
        Case "PTN_DESCRIPTION_EN"
            iProperties.Value("Custom", "PTN_DESCRIPTION_EN")=oPromptEntry
    End Select
    Next
Next
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
bradeneuropeArthur
Are the custom properties PTN-_*** in the drawing available already? Otherwise you need to add them first with either code or manually.
With
.doc.propertyset.item(4).add(***,###)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Dim textValue As String
    textValue = "Here's some text."
customPropSet.Add(textValue, "TextProp")
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
johan.degreef
Yes they are in the drawing (I added them to my dwg template), but stay empty after running the rule
bradeneuropeArthur
Dim oSheet As Sheet
Dim oPromptEntry
Dim oCurrentSheet
i = 1
  'i = i+1
        Case "<PTN_DRAWING>"
        Case "<PTN_REVISION>"
        Case "<PTN_TITLE_EN>"
        Case "<PTN_DESCRIPTION_EN>"
    End Select
    Next
Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
