Launch iLogic rule from .net -> changing name
cadmageren
cadmageren
Hi. I have mad a vb.net routine, to automatically launch a specific rule.
The launch works, however after each time I run the program, a _1 is added to the
Rulename:
Update Filestructure_1_1_1_1_1_1_1_1
Any other suggestion on how to run a rule, or can someone tell me why this is happening?
/Michael Christoffersen
    Sub LaunchRule(ByVal sRuleName As String)
        Try
            For Each oAddIn As ApplicationAddIn In mInvApp.ApplicationAddIns
                If oAddIn.DisplayName.Contains("iLogic") Then
                    oAddIn.Activate()
                    Dim iLogicAuto As Object = oAddIn.Automation
                    Dim rules As Object
                    rules = iLogicAuto.rules(mInvApp.ActiveDocument)
                    If (Not rules Is Nothing) Then
                        For Each Rule As Object In rules
                            If InStr(Rule.Name, sRuleName, Microsoft.VisualBasic.CompareMethod.Text) Then
                                ' Rule.run()
                                iLogicAuto.runrule(mInvApp.ActiveDocument, Rule.Name)
                                Exit Sub
                            End If
                        Next
                    End If
                End If
            Next
        Catch ex As Exception
        End Try
    End Sub
MjDeck
This is a bug in iLogic, and we should be able to fix it.
Here's a workaround that will not change the name of the rule.  Instead of looping thru the rules, you can ask for the rule by name:
Dim rule As Object = iLogicAuto.GetRule(mInvApp.ActiveDocument, sRuleName)
If (rule IsNot Nothing) Then
iLogicAuto.RunRuleDirect(rule)
End If
Mike Deck
Software Developer
Autodesk, Inc.
